GPU Compute Software
Ask questions about Intel® Graphics Compute software technologies, such as OpenCL* GPU driver and oneAPI Level Zero
352 Discussions
OpenCL compiler backend issue with Drivers >= 30.0.101.1069
Scott_S_2
Hi all,
I have just upgraded to the latest Intel Graphics Driver and I can no longer build opencl programs from spirv. It seems image3d write is broken/missing as I get the following error for a simple opencl kernel:
failed to build opencl program:
error: undefined reference to `__builtin_spirv_OpImageWrite_img3d_wo_v3i32_v4f32'
in function: '__builtin_spirv_OpImageWrite_img3d_wo_v3i32_v4f32' called by kernel: 'driver_test2'
error: backend compiler failed build.
here is a simple kernel that triggers this:
#include <opencl_memory>
#include <opencl_work_item>
#include <opencl_image>
#include <opencl_integer>
using namespace cl;
kernel void driver_test(
    image3d<float4, image_access::write> dst_vol
    const int3 dst_coords(get_global_id(0), get_global_id(1), get_global_id(2));
    float4 source_sample(0.0f,0.0f,0.0f,0.0f);
    dst_vol.write(dst_coords, source_sample);
and the cpp part:
#include "CL/cl.h"
#include <iostream>
#include <fstream>
#define MAX_PLATFORM_SIZE 256
#define MAX_DEVICE_SIZE 256
std::vector<unsigned char> load_file(const std::string& file)
    std::fstream input(file, std::ios::in | std::ios::binary | std::ios::ate);
    auto size = input.tellg();
    input.seekg(0, std::ios::beg);
    std::vector<unsigned char> binary(size);
    input.read((char*)binary.data(),size);
    input.close();
    return binary;
void driver_test()
    std::vector<unsigned char> data = load_file("driver_test.spir");
    cl_device_id device_id[256];
    cl_platform_id platform_id[256];
    cl_uint ret_num_devices;
    cl_uint ret_num_platforms;
    char buf[4096];
    cl_int ret = clGetPlatformIDs(0, 0, &ret_num_platforms);
    ret = clGetPlatformIDs(ret_num_platforms, platform_id, &ret_num_platforms);
    if (ret != CL_SUCCESS) {
        std::cout << "something went wrong in clGetPlatformIDs" << std::endl;
        return;
    for (unsigned int i=0; i<ret_num_platforms; i++)
        ret = clGetPlatformInfo(platform_id[i], CL_PLATFORM_NAME, sizeof(buf), buf, NULL);
            std::cout << "something went wrong in clGetPlatformInfo" << std::endl;
            return;
        std::cout << "Platform[" << i << "]: " << buf << std::endl;
        ret = clGetDeviceIDs(platform_id[i], CL_DEVICE_TYPE_ALL, MAX_DEVICE_SIZE, device_id, &ret_num_devices);
            std::cout << "something went wrong in clGetDeviceIDs" << std::endl;
            return;
        for (unsigned int j=0; j<ret_num_devices; j++) {
            ret = clGetDeviceInfo(device_id[j], CL_DEVICE_NAME, sizeof(buf), buf, NULL);
                std::cout << "something went wrong in clGetDeviceInfo" << std::endl;
                return;
            std::cout << "Device Name: " << buf << std::endl;
            ret = clGetDeviceInfo(device_id[j], CL_DEVICE_VENDOR, sizeof(buf), buf, NULL);
                return;
            std::cout << "Device Vendor: " << buf << std::endl;
        std::cout << std::endl;
    cl_context context = clCreateContext( NULL, 1, &device_id[0], NULL, NULL, &ret);
    cl_int err = 0;
    cl_program program = clCreateProgramWithIL((cl_context)context, data.data(), data.size(), &err);
    if(err != CL_SUCCESS){
        std::cout << "failed to create opencl program with IL " << std::endl;
        return;
    // sometimes crashes here
    err = clBuildProgram(program, 1, &device_id[0], NULL, NULL, NULL);
    cl_int build_status;
    err = clGetProgramBuildInfo(program, device_id[0], CL_PROGRAM_BUILD_STATUS, sizeof(cl_build_status), &build_status, NULL);
    if(build_status != CL_SUCCESS){
        size_t ret_val_size;
        err = clGetProgramBuildInfo(program, device_id[0], CL_PROGRAM_BUILD_LOG, 0, NULL, &ret_val_size);
        std::vector<char> build_log(ret_val_size+1,0);
        err = clGetProgramBuildInfo(program, device_id[0], CL_PROGRAM_BUILD_LOG, ret_val_size, build_log.data(), NULL);
        build_log[ret_val_size] = '\0';
        std::cout << "failed to build opencl program: \n" << build_log.data() << std::endl;
I've been rolling back the driver versions and the earliest driver where this happens is: 30.0.101.1069
Earlier driver version work fine
Sometimes it crashes at clBuildProgram too.
I have attached the .cl, cpp and .spir files. We use:
SPIRV-LLVM
SPIR
libclcxx
to generate the spirv file. I've attached the generated spirv for easier testing.
Any help would be appreciated.
Scott
System Setup Information:
System Used: Inspiron 3670
CPU SKU: Intel(R) Core(TM) i3-8100 CPU @ 3.60GHz 3.60 GHz
GPU SKU: Intel(R) UHD Graphics 630
System BIOS Version: Dell Inc. 1.3.4, 24/05/2018
Graphics Driver Version: 30.0.101.1069
Operating System: Windows 10 Pro
OS Version: 10.0.19042 Build 19042
API: OpenCL
Occurs on non-Intel GPUs?: no tested
AlHill
@Scott_S_2 One post is enough.   Stay with your original post.
Scott_S_2
@AlHill  the system continuously marked my posts as SPAM, without any extra information, hence the weird state of multiple posts appearing
AlHill
Well, the system did not mark as spam the multiple post that I saw.
Ben_A_Intel
Thanks for the thorough description and the reproducer!
As best I can tell, the issue is caused by using a three-component vector as the image coordinate for the 3D image write:
The SPIR-V spec - and specifically the OpenCL SPIR-V environment spec - isn't clear whether this should be supported or not.  But, since the corrosponding OpenCL C function takes a four-component vector as the image coordinate for a 3D image write, it looks like this is the only SPIR-V version we currently have implemented in our compiler:
https://github.com/intel/intel-graphics-compiler/blob/master/IGC/BiFModule/Implementation/images.cl#L997
I'll try to think if there is a workaround for this issue.
In the meantime, I'd suggest filing an OpenCL spec issue to clarify whether three-component coordinates are valid for 3D image writes, or if four-component coordinates are required:
https://github.com/KhronosGroup/OpenCL-Docs/issues
PS: For whatever it's worth, our CPU OpenCL device does not seem to be accepting the three-component vector either.
Scott_S_2
This is interesting, although confusing as the previous driver versions seem to handle this fine.  I'm guessing something has changed between versions with the SPIRV handling.
I also get errors with regular C kernels when using LLVM 15 and LLVM-SPIRV generated spirv e.g.
__kernel void window_level(
    __read_only image2d_t srcImg,
    __write_only image2d_t dstImg,
    float window_bottom,
    float width_rcp
   int2 coord = (int2) ((int)get_global_id(0), (int)get_global_id(1));
   int2 size = get_image_dim(srcImg);
   if(coord.x >= size.x || coord.y >= size.y){
       return;
   sampler_t sampler = CLK_FILTER_NEAREST | CLK_NORMALIZED_COORDS_FALSE | CLK_ADDRESS_CLAMP;
   int4 src_value = read_imagei(srcImg, sampler, coord);
   int4 dst_value;
   dst_value.x = (int)((src_value.x - window_bottom) * width_rcp);
   if(dst_value.x > 255){ dst_value.x = 255; }
   if(dst_value.x < 0){ dst_value.x = 0; }
   write_imagei(dstImg, coord, dst_value);
gives me the following error
error: undefined reference to `__builtin_spirv_OpImageWrite_img2d_wo_v2i32_v4i32_i32'
in function: '__builtin_spirv_OpImageWrite_img2d_wo_v2i32_v4i32_i32' called by kernel: 'window_level.1'
So this seems to be a common issue with newer driver versions.
I can't just change the coords to int4 as it complains that write_imagei cannot convert the input from int4 to int2, and dst_vol.write(dst_coords, source_sample) cannot convert from int4 to int3 etc.
In the meantime I'll post in the OpenCL-Docs issue tracker.
Scott
Scott_S_2
for this particular C kernel case: passing -spirv-max-version=1.2 solves the 2D undefined reference issue
