链接已复制
Hello Deligicik,
Thank you for reaching out. I understand that you're experiencing performance issue with your new desktop setup compared to your previous laptop. Let us work together to identify the issue that is causing this so that I may provide an appropriate solution.
- Have you check your BIOS if Resizable Bar (ReBAR) is enabled?
- What is your current BIOS Version
- Have you considered using Dual Memory Ram?
- What is your power plan settings?
- Do you encounter this issue with other games?
Please generate an SSU report to help me further analyze important details on your system. To generate the SSU report, please refer to the article: How to get the Intel® System Support Utility Logs on Windows*. Please send us the generated SSU.txt file.
I look forward to your response!
Robbie R.
Hello Deligicik,
Robbie R.
Hello Deligicik,
John S.
