656 Diskussionen
FPS drop/lagging issue on my I5-12450H Intel graphics Laptop
Atom366
Einsteiger
9.934Aufrufe
Am having issues while gaming (this doesn't happen always but sometimes like at least once a day) when suddenly the FPS drops completely to 10FPS and it starts lagging/stuttering and after restarting the laptop it works fine for a moment but starts lagging again. This is a recent issue because i have had this laptop for a while had no issue, but from now am having this issue from a week or two I kinda believe it is maybe because of a recent driver update that I have got.
I have attached my SSU file so please go through that and help.
17 Antworten
Senkuchan
Geschätzter Beitragender II
9.900Aufrufe
After checking the logs I can confirm that your driver version is up to date according to the honor website since you’re using an honor and the driver they have is custom made for computer: https://www.hihonor.com/uk/support/downloads/
Your system model is HONOR MagicBook X 16.
If you still want to try another driver and see if it makes any difference, you can use the generic driver from the Intel website. Here is the link: https://www.intel.com/content/www/us/en/download/785597/intel-arc-iris-xe-graphics-windows.html
For more troubleshooting steps, please refer to the following articles:
https://www.intel.com/content/www/us/en/support/articles/000030302/graphics.html
https://www.intel.com/content/www/us/en/support/articles/000005629/graphics/processor-graphics.html
https://www.intel.com/content/www/us/en/support/articles/000038757/graphics.html
Atom366
Einsteiger
9.881Aufrufe
I will try these and let you know, thanks for the feedback
Atom366
Einsteiger
9.854Aufrufe
I tried but the issue persists.
Senkuchan
9.841Aufrufe
I would like to know if you have followed the other steps in this article: https://www.intel.com/content/www/us/en/support/articles/000030302/graphics.html
Also what is the name of the game that is causing you problems?
Atom366
Einsteiger
9.818Aufrufe
1st one, I tried and the specs are suitable (game: valorant) and when the FPS drops I cam back to check my CPU usage which is at 10-15% but the clock speed has drastically dropped below 2GHz (which should be this processor's base speed) to 0.50 - 0.75Ghz, so I thought maybe its cuz my lap is overheating so the CPU is throttling but its not the case max temp is around 96-97 degree Celsius, and btw this happen all the times i game, only sometimes and when I restart the LAP it works fine, also btw the whole lap laggs when cps drops below base speed,
2nd one, I have installed the intel driver assistant and it installed intel arc and updated my graphic driver to the latest one but no difference in issue.
3rd, I guess its the same as 2nd one.
The game is Valorant.
Atom366
Einsteiger
9.807Aufrufe
btw here's my IPDT test results
Senkuchan
9.727Aufrufe
I found this link from the Intel website: https://www.intel.com/content/www/us/en/support/articles/000095100/graphics.html
It seems that they are investigating this issue and they provided some work around.
Atom366
Einsteiger
9.714Aufrufe
Ohh but its much severe now anyway can you please let me know when this gets a fix?
VonM_Intel
9.608Aufrufe
Hi, Atom366.
Thank you for posting in our Community.
I understand that you are having fps drop or lagging issues, while gaming on the Valorant game. However, Intel is currently investigating this issue, and we will do further research on this matter and post the response on this thread once available. In the meantime, please turn on the Vignette option in the game settings to reduce stuttering, as a workaround. The Vignette option is a visual effect that darkens the edges of the screen, which can improve the performance and stability of the game.
Von M.
masa10
Einsteiger
9.082Aufrufe
Hi
I am having same issue but there is no problem in GPU besause I have nvidia RTX 4050 and the issue is same as atom's there is problem in CPU can I do something about it? CPU goes to 95 degrees and cca 50 wats and than it suddenly drops to 60 degrees and 15 wats and it starts to lag a lot from like 140 fps to 40 it happens when I play fortnite and rainbow six seige too.
VonM_Intel
9.437Aufrufe
Hi, Atom366.
Apologize for the long wait.
We are still in the process of replicating and isolating the issue. However, I would like to share with you this article/link, (https://www.intel.com/content/www/us/en/support/articles/000089687/graphics.html) - Low Performance While Playing Valorant* Using Intel® HD Graphics 530, as it seems that you only have an integrated graphics card.
If the issue remains unresolved, please let us know.
Von M.
Atom366
Einsteiger
9.296Aufrufe
Ok I will try those solutions from the article, but please let me know when this gets resolved.
David48
Einsteiger
9.357Aufrufe
 Can you please let me know when this issue gets a fix? I also have this problem on my lenovo laptop.
ACarmona_Intel
Mitarbeiter
9.232Aufrufe
Hello Atom366,
We are checking in with you to see if you have already tried the troubleshooting steps that we have provided, and may we know what the result is?
By the way, we are still in the process of replicating and isolating the issue that we have. We will update this link or article once we have the solution.
Thank you, and have a great day!
Carmona A.
VonM_Intel
9.056Aufrufe
Hi, Atom366.
I trust you're doing well.
I have not heard back from you we will close this inquiry now. If you need further assistance, please submit a new question as this thread will no longer be monitored.
Hi @masa10.
I empathize with your situation and the issue you are facing. However, I kindly request that you create a new thread for your case. This will allow us to focus on your specific problem and provide you with better assistance.
Von M.
Atom366
Einsteiger
8.989Aufrufe
ISSUE RESOLVED!!!!
Hey guys My issue got fixed when I cleaned my Fan vents, there was excess dust tht got stuck in my air vents so the air couldnt flow properly, after i cleaned it my Laptop is back to normal condition so anyone who is facing this issue please check you air vents and clean any dust blocking ur vents. (highly suggest doing this atleast every 6 months)and THANK YOU intel community/support for your assistance.
@masa10 @David48 @Senkuchan FPS drop/lagging issue on my I5-12450H Intel graphics Laptop
David48
Einsteiger
8.686Aufrufe
I really thank to you, and the intel community/support for your assistance.
Antworten
