718 Discussions
Intel HD 630 FPS Cap at 60 in Valorant - Tried Everything, Seeking Solutions!
Newer
Hey folks,
So, I've been running into this FPS issue with my Intel HD 630 while playing Valorant. The problem is that no matter what I do, the FPS seems to be capped at 60. I've tried the usual suspects like disabling full screen optimization and other tweaks, but no luck so far.
One suggestion I came across was turning off VSync from the Intel Command Centre. However, I couldn't find any option for that. I've also made sure I'm rocking the latest drivers, but the problem persists.
Any of you legends out there faced a similar problem and found a way around it? I'm all ears for any step-by-step solutions or alternative fixes you might know.
Thanks in advance!
Labels (2)
VonM_Intel
Hi, Newer.
Thank you for posting in the Intel Communities. We would be more than glad to help you solve the problem regarding the FPS issue with the Intel HD 630 while playing games especially Valorant, hence for us to provide you with an accurate recommendation, please provide the following information:
  • What is the model of the motherboard?
  • If this is a laptop, what is the model of it?
  • Was the game Valorant working fine before on this same machine?
  • Did you make any recent hardware/software changes besides the driver update that might cause this issue?
  • When did the issue start?
  • Which Windows* version are you using?
  • Does the problem happen at home or in the work environment?
Kindly attach the SSU report so we can verify further details about the components in your platform, check all the options in the report including the one that says "3rd party software logs": (https://www.intel.com/content/www/us/en/download/18377/25293/intel-system-support-utility-for-windows.html)
For any questions, please let me know.
Von M.
JayB_Intel
Hi Newer,
Were you able to check the previous post?  Let us know if you still need assistance.
Jay B.
JayB_Intel
Hi Newer,
We have not heard back from you so we will close this inquiry now. If you need further assistance, please post a new question, as this thread will no longer be monitored.
Kind regards,
Jay B.
