連結已複製
Hi rmacjus,
Apologies for the delay on my response. Please note that this is an OEM device. I’ll assist you with general troubleshooting steps, but if the issue persists, you’ll need to contact the Original Equipment Manufacturer. They may have altered features, incorporated customizations, or made other changes to ensure better compatibility with your system.
Please make sure you provide the following basic information when reporting a bug:
- What is the graphics driver you are using?
- Confirm you are using the latest WHQL graphics driver available (let us know the exact driver version you are using).
- A clean driver installation using DDU in safe mode is recommended. Follow this link for instructions.
- You could also test using the latest Beta driver. Our Beta drivers go through all Intel quality assurance processes and are safe to use for evaluation.
- Provide us with the Intel SSU report from your system.
- If you do not wish to submit the SSU report then at least provide us with the following information about your system:
- Processor make and model.
- Power Supply make and model.
- Motherboard make and model.
- Amount of memory (RAM).
- Operating System version/build number.
- Tell us the steps to reproduce the issue (this is very important!).
Dean R.
Hi rmacjus,
Dean R.
Hi rmacjus,
Since I haven't received a response from you, I will be closing this inquiry. If you need further assistance, please submit a new question, as this thread will no longer be monitored.
Dean R.
