Ankündigungen
673 Diskussionen
Intel i9 13900h gaming laptop CPU voltage issues?
ƚɾιρʅҽ
Einsteiger
16.454Aufrufe
So I have an ASUS ROG Zephyrus m16 w/ i9 13900h cpu and was wondering if the CPU voltage problems spread to this variant of Intel CPU’s? And if so, how can I go and check in under volt my CPU for a not to cause damage? And how can I tell if there’s damage already done? I have game crashes that happen all the timeand my CPU seems to be throttling at 90°C at times and I have an issue where the monitor and keyboard flick off randomly at random. and my CPU seems to be throttling at 90°C at times and I have a issue where the monitor and keyboard flick off randomly at random moments while I’m using the device. Any help would be greatly appreciated.
Here is a little snippet of something I was just able to capture but at the beginning of the video you’re seeing the middle of the issue happening I’ll be gaming and all of a sudden the keyboard monitor will shut off randomly and click back on but sometime it’ll shut off and not click back on and I’ll be forced to hard reset the System. I’ve also been experiencing a lot of of game crashes so any information on this issue would be awesome!
e: also on a side note, I’m now experiencing micro stutter when gaming.
12 Antworten
JeanetteC_Intel
16.351Aufrufe
Hello ƚɾιρʅҽ,
I'll check on this query and I will post an update once it's available.
JeanetteC.
JeanetteC_Intel
16.278Aufrufe
Hello ƚɾιρʅҽ,
I would like to know more about your system details to fully understand where the issue truly lies. Please help provide the following information below:
1) Games affected (crashing).
2) What application is used to monitor the CPU temperature?
3) What specific applications are running when you experience when your monitor and keyboard flick off randomly? Is the temperature high during this times?
Additionally, we highly appreciate you sharing your system configuration so we can fully check and provide you with an accurate fix. This could be possible by downloading the Intel® System Support Utility for Windows* software. When the download is complete, launch SSU.exe.
  1. Scan: Check the box Everything.
  2. Click Scan.
  3. Review: When finished scanning, click Next.
  4. Click Save (.txt).
I will wait for your reply.
JeanetteC.
ƚɾιρʅҽ
Einsteiger
15.921Aufrufe
Hello, the game that crashes is Diablo Immortal and the software that I use to monitor my temps is gHelper. Applications that are running are gHelper, Diablo Immortal, Microsoft Edge (sometimes), Reddit, Discord, NVIDIA Control Panel, Battle.net, Windows Defender, nothing crazy intensive or outside the power limits.. Diablo Immortal is NOT a graphic intensive game either.. I'm also getting huge micro stuttering in Diablo Immortal as well as Diablo 4.
JeanetteC_Intel
15.875Aufrufe
Hello ƚɾιρʅҽ,
Thank you so much for sharing the details and log file I asked about this. I would need to check this further, but before doing so, please download and run the Intel® Processor Diagnostic Tool. Please share a screenshot of the results and a copy of the log file (.txt). You may check this User Guide page 10 (Running IPDT from GUI).
I will wait for your reply so I can proceed with further checking.
JeanetteC.
ƚɾιρʅҽ
Einsteiger
15.862Aufrufe
Ok, I ran the stress test and it looks like it passed.. the CPU was up to 95C under load but it looks like that is normal. it didn't go beyond that, it stayed 95C pretty consistently.
JeanetteC_Intel
15.479Aufrufe
Hello ƚɾιρʅҽ,
Thank you for sharing this update.
The processor is still in good health since the test passed. The SSU logs show that the BIOS version is version 312, but on your system manufacturer's download page, the latest BIOS firmware available is version 310. So I highly recommend reaching out to your system manufacturer's support team, to check if the latest version of firmware is the one currently installed, if they have a new BIOS that you can upgrade to, and if the Intel Default setting is available, that you can select. If none, you may have to ask their support team to diagnose your system properly, to check if there's any hardware failing that causes the game crashes and high temps.
Let us know if you still have any other concerns that I can be of help.
JeanetteC.
Tomba
Einsteiger
15.227Aufrufe
As everyone know that 13 and 14th generations are broken. I got suggestion from Intel support team to update my mainboard BIOS, it is much worse right now. DONT DO IT. Intel have to release new clear CPUs and replace all **bleep**.
Maxtwofortwosix
Einsteiger
12.631Aufrufe
I have an i7 8086k with a rtx 3070ti, it IS better than my i9 13900H with a rtx 4070. I didn t understand what IS wrong with this i9 . A lot of crash with the beta of black ops 6 and other games. M'y futur computer will be nature and earth Wonder. Non more bad Electronics.
igtaz
Einsteiger
12.667Aufrufe
Hey Tomba, did you happen to identify the issue with your ASUS? I am having the same issue with mine, same CPU... Thanks!
Tomba
Einsteiger
12.594Aufrufe
If random crashes started in your system, there is no solution, it is over, change it asap or replace with AMD as i did, dont waste rime
ƚɾιρʅҽ
Einsteiger
12.590Aufrufe
These are laptop CPU’s, you can’t just change them can you? I’m still getting crashes constantly in Diablo 4.
igtaz
Einsteiger
11.679Aufrufe
Thanks @Tomba I guess I am going to have to start the RMA process. I have an Acronym edition, I hope they still have some spares, but I doubt it. Even if they do, I am not sure I want a new one, it's going to start with BSODs after a while, and my warranty will be gone by then....
Antworten
