653 Discussions
Iris xe issues in fortnite with i7 1165g7
UserRandom
I have a i7 1165g7 with iris xe 96, In every game I have played so far, it has been fine, but with Fortnite in a actual game (not customs) it lags like crazy and also freezes quiet a bit. Is this a driver issue, or a issue with my iris xe?
DeividA_Intel
Hello UserRandom,
Thank you for posting on the Intel® communities. I am sorry to know that you are having issues with your Intel® Iris® Xe Graphics.
1. Run the Intel® System Support Utility (Intel® SSU) to gather more details about the system.
2. Is this issue recent? Or, was it present from the first time you played the game?
3. Did you make any hardware/software changes before the issue was present?
Deivid A.
UserRandom
I've always had this issue from the first time I downloaded the game. However I do not have problems in any other games such as Valorant. I also have 8gb of ram and the latest iris xe graphics driver. I also have no problems using emulators and non fps games. I play Fortnite on lowest pre-set at performance mode.
DeividA_Intel
Hello UserRandom,
Thanks for your response. In this case, I recommend you test the graphics drivers from Asus.
If the issue persists, try one more time a clean install of the Intel drivers.
Deivid A.
UserRandom
Windows has installed the one from asus before in an update and it had even worse performance compared to the latest one from intel (had issues aswell).
UserRandom
I have the latest one from intel which i clean installed, and that has issues in fortnite. The one from Asus is from 2022 so I doubt It could offer better performance
Jose_Intel
Hello UserRandom
Thank you for your reply.
Please allow us to research about this issue internally, as soon as we have any update we will let you know.
Jose B.
UserRandom
I found out the reason I was getting so much lag was because my gpu usage was quiet low on performance mode at low graphics, and it would often drop to 1-3% a lot, causing a lot of freezes, I changed the graphics settings to high, with epic view distance and now its mostly consistent around 60% usage drops 1ns or 2wice at the start of a game and stutters a lot less. the stuttering is because it is at high graphics which can be quiet intensive for a igpu. I'm just wondering why does the gpu usage drop so much on low graphics at performance mode. And 1 more thing. When I try to change to directx 12 and restart the game, its on DirectX 11, and when I do the same process again, it's still on DirectX 11 and won't change to DirectX 12. There is no incompatibility issue or anything like that. It just won't change to DirectX 12 for some reason.
Jose_Intel
Hello UserRandom
Thank you for patiently waiting.
We were testing the game in our lab, we did not have any issue or low performance. We are glad to know you found a solution, thank you for taking the time to share this fix, and hopefully, it may help other community members experiencing similar behavior.
Since the thread is now solved, we will proceed to close it. Please keep in mind that this thread will no longer be monitored by Intel. In case you experience another issue with the game, please contact the game developers.
Jose B.
