702 Discussions
why my intel graphic command center not working
DarkJerry
my intel graphic command center just stuck at loading screen
DeividA_Intel
Hello DarkJerry,
Thank you for posting on the Intel® communities. I want to understand what happened just as much as you do and I will do my best to help you out.
Before I continue further, I would like to confirm the following:
1. What is the brand and model name of your processor?
2. What is the operating system installed as well as the version and build?
3. Was the tool working before? If so, when did it start to fail?
4. Did you notice this issue after a system update (driver, windows, BIOS, etc)?
Deivid A.
DarkJerry
Intel(R) Core(TM) i5-8365U CPU @ 1.60GHz 1.90 GHz
windows 10 22h2
the tool working was working before but after i updated my windows it start to fail
DeividA_Intel
Hello DarkJerry,
I want to know if the tool is still having issues or if is working now. Let me know if you need further assistance.
Deivid A.
DeividA_Intel
Hello DarkJerry,
Thanks for the confirmation. To help you fix this issue I recommend you to update your graphics driver.
Driver: https://www.intel.com/content/www/us/en/download/776137/intel-7th-10th-gen-processor-graphics-windows.html
Also, you can uninstall the Intel® Graphics Command Center from "Apps & Features" and reinstall it from the Microsoft Store.
Steps: https://www.intel.com/content/www/us/en/support/articles/000055840.html
Additionally, you can repair or reset the app via Windows Settings:
  1. Open Settings > Apps > Apps and features.
  2. Locate the Intel® Graphics Command Center application and select Advanced options.
  3. Under Reset, click Repair.
Deivid A.
DarkJerry
it doensnt work is there another solution?
DeividA_Intel
Hello DarkJerry,
Thanks for your confirmation. I would like to investigate this behavior, please attach the report from the Intel® System Support Utility (Intel® SSU):
Run the Intel® System Support Utility (Intel® SSU) to gather more details about the system.
Deivid A.
DarkJerry
DeividA_Intel
Hello DarkJerry,
After checking your thread, I would like to know if you need further assistance.
If so, please let me know.
Deivid A.
Alberto_R_Intel
DarkJerry, Thank you very much for providing the SSU report.
We will now do further research on this matter to try to find a possible solution for this scenario. As soon as I get any updates, I will post all the details on this thread.
Albert R.
Alberto_R_Intel
Hello DarkJerry, I just received an update on this matter.
After reviewing the case we would like to let you know that IGCC should be installed from MS store. Fixing and resetting should be done from Windows advanced options related to the app. If already done, try to update/reinstall .NET latest version. This is MS/Windows as well.
Albert R.
