Buenas , necesito ayuda tengo un procesador i5 9300h y cuando juego Fortnite o Minecraft el uso de CPU esta al 100% lo que ocasiona cortes y bajones de FPS.Esto antes no me pasaba no eh tocado nada y antes siempre jugaba entre 50 y 60 de CPU en estos juegos.
Ya no se que hacer necesito ayuda por favor ya revise si tiene algún virus o un proceso en segundo plano y no , no es el caso todo esta perfecto.
Hello RyZe_GTX
Our support is only provided in English. To better assist you, we use a translation tool, hence; the translation may not be completely accurate.
In order to better assist you, please provide me with the following:
- When did the issue start?
- Was there a major change before the issue started, maybe a game or system update?
- Could you provide me with a screenshot of the task manager under the performance tab while running the game? This will help us confirm the utilization of your CPU.
- Intel
System Support Utility (Intel SSU) - Download the Intel SSU (https://www.intel.com/content/www/us/en/download/18377/25293/intel-system-support-utility-for-window...)
- Open the application and click on "Scan" to see the system and device information. By default, Intel
SSU will take you to the "Summary View." - Click on the menu where it says: "Summary" to change it to "Detailed View."
- To save your scan: click on "Next"; then "Save."
Jean O.
Hello RyZe_GTX,
I hope you are doing fine.
Jean O.
Hello RyZe_GTX,
I have not heard back from you. So we will close this thread. If you need any additional information, submit a new question, as this thread will no longer be monitored.
Best regards.
Jean O.
