Hi, I have an Intel i12700k, 32Gb ram.
While my EVGA3070Ti gets swapped out, I noticed that I have no DirectX 12_2 Ultimate graphics, shows as not being enabled.
I am using Intel Arc graphics driver Ver 31.0.101.3802, Dxdiag shows Ultimate as disabled.
Also Rebar is greyed out and Gpu-z indicates disabled as well! It is enabled on motherboard bios.
Any ideas... Dxdiag txt, Cpu-z, Gpu-z attached
Windows 11 pro Version 10.0.22621 Build 22621
Asus Tuf Gaming Z690 Plus WiFi D4 Bios Ver 2103
32Gb DDR4 3200 Corsair ram.
Hello PenPusher,
Thank you for posting on the Intel️® communities. They are sorry to hear that you are experiencing issues with your system.
Regarding your issue, it is important to mention that your processor supports DirectX12.
Remember that DirectX* drivers must be installed separately and are included in Windows* or can be installed via Windows Update. Refer to the following link for more information on How to install the latest version of DirectX*.
Jean O.
Hello PenPusher,
I hope you are doing fine.
Jean O.
Hello PenPusher,
I have not heard back from you. So I will close this thread. If you need any additional information, submit a new question, as this thread will no longer be monitored.
Best regards.
Jean O.
