Hello Grier,
请注意,我只能用英语为您提供帮助。我使用网络翻译工具来翻译此回复,因此可能会有一些不准确的翻译。接下来,我将用英语回答您。
To get a better understanding of the issue and be able to provide an effective recommendation, please provide the missing key information here:
1) Has the game worked before, and did the issue only start recently?
2) If the issue began recently, what changes were made before it started?
3) What is the current version of the graphics driver installed, and where did you obtain it?
4) Where did you get the game? (Steam, Epic, etc.)
5) Please provide the Intel SSU report from your system so I can thoroughly check and offer an accurate solution. This could be possible by downloading the Intel® System Support Utility for Windows* software. When the download is complete, launch SSU.exe.
- Scan: Check the box Everything.
- Click Scan.
- Review: When finished scanning, click Next.
- Click Save. *Attach the SSU log file as you reply.
I look forward to your reply.
JeanetteC.
Hello Grier,
I will look into this internally and will get back to you once I have an update.
JeanetteC.
Hello Grier,
I am still working on this issue you raised. Can you confirm that the device you have? (https://gpd.hk/gpdg1videoreview)
Have you tried clean installation of the latest driver, version 32.0.101.6795, using Display Driver Uninstaller (DDU)?
If the issue persists, have you tried contacting your device manufacturer for their latest OEM graphics drivers to install?
I hope to hear from you soon.
JeanetteC.
Hello Grier,
Let us know if you have any questions.
JeanetteC.
Hello Grier,
Since I haven't received any response from you recently, I will go ahead and close this thread. If you require help in the future, please submit a new inquiry, as this thread will no longer be monitored.
Sincerely,
JeanetteC.
