661 Discussions
Request to optimize the performance of Xe nuclear display in extreme countries-low GPU occupancy lea
Grier
Riders RepublicRequest to optimize the performance of Xe nuclear display in Riders Republic-low GPU occupancy leads to insufficient frames.目前使用搭载Intel Xe核显(Iris Xe Graphics 96EU)的设备进行游戏时,遇到GPU占用率无法提升(通常低于50%)且帧数较低的问题。即使调低画质设置,性能仍无明显改善,疑似存在驱动或硬件调度优化空间。
Labels (2)
JeanetteC_Intel
Hello Grier,
请注意,我只能用英语为您提供帮助。我使用网络翻译工具来翻译此回复,因此可能会有一些不准确的翻译。接下来,我将用英语回答您。
To get a better understanding of the issue and be able to provide an effective recommendation, please provide the missing key information here:
1) Has the game worked before, and did the issue only start recently?
2) If the issue began recently, what changes were made before it started?
3) What is the current version of the graphics driver installed, and where did you obtain it?
4) Where did you get the game? (Steam, Epic, etc.)
5) Please provide the Intel SSU report from your system so I can thoroughly check and offer an accurate solution. This could be possible by downloading the Intel® System Support Utility for Windows* software. When the download is complete, launch SSU.exe.
  1. Scan: Check the box Everything.
  2. Click Scan.
  3. Review: When finished scanning, click Next.
  4. Click Save. *Attach the SSU log file as you reply.
I look forward to your reply.
JeanetteC.
Grier
亲爱的 JeanetteC,
感谢您的跟进!以下是补充信息:
1.该游戏自安装以来始终存在GPU占用低的问题,从未流畅运行过。
2. 近期未进行系统或驱动更新。
3. 当前显卡驱动版本:32.0.101.6793(从英特尔官网手动下载安装)。
4. 游戏购买平台:Ubisoft Connect。
5. 已通过Intel SSU生成诊断报告,请查收附件。
期待您的进一步建议!
此致,
[李敏浩]
附件:
JeanetteC_Intel
Hello Grier,
I will look into this internally and will get back to you once I have an update.
JeanetteC.
JeanetteC_Intel
Hello Grier,
I am still working on this issue you raised. Can you confirm that the device you have? (https://gpd.hk/gpdg1videoreview)
Have you tried clean installation of the latest driver, version 32.0.101.6795, using Display Driver Uninstaller (DDU)?
If the issue persists, have you tried contacting your device manufacturer for their latest OEM graphics drivers to install?
I hope to hear from you soon.
JeanetteC.
JeanetteC_Intel
Hello Grier,
Let us know if you have any questions.
JeanetteC.
JeanetteC_Intel
Hello Grier,
Since I haven't received any response from you recently, I will go ahead and close this thread. If you require help in the future, please submit a new inquiry, as this thread will no longer be monitored.
Sincerely,
JeanetteC.
