Resizable BAR issue
debianation
Hello all,
   I activated resizable bar and now Division 2 will not launch, any ideas on a solution?
Hugo_Intel
Hello debianation
Thank you for posting on the Intel Gaming Communities.
Have you confirmed that Resizable BAR is causing the issue by disabling it again and checking if the game launches? If so, when having Resizable BAR enabled is there any error message when trying to launch the game? Also, Could you please confirm if this is the only game affected by this issue?
I would like to check your system information so we can know your GPU model, drivers, and other hardware details so we can check for updates and possible compatibility issues. Please share with us a log file from the Intel® System Support Utility.
Hugo O.
Hugo_Intel
Hello debianation
We are interested in helping you with this issue, please let us know if there is any error message when trying to play the game as well as if the game can be launched again after disabling Resiable BAR. We would also appreciate it if you could share your system information through the SSU report we requested in our previous post.
Hugo O.
Hugo_Intel
Hello debianation
We did not receive the log files and your confirmation whether the issue is actually caused by the Resizable Bar, so in this case we will proceed to close this thread, however, if you need further support or continue to experience this problem feel free to open a new topic.
Hugo O.
