I am using a 32:9 monitor with a resolution of 5120x1440.
So far, I have been using the built-in KVM switch, and with my laptop that has an Intel Iris graphics chip, it worked fine.
Now, I am using a separate KVM switch.
On my other PC (NVIDIA), I was able to manually set the resolution to 5120x1440, and it works.
On my laptop, I downloaded and installed the Intel Graphics Command Center (Beta).
When I try to manually set the resolution to 5120x1440 there, I get an error message: "Bad Parameters".
How can I manually set the desired resolution? Is there a solution?
It worked before, the Intel graphics chip supports it, and the KVM switch does as well.
Lars
Hello Lars5,
Thank you for posting in the community. I have a few questions regarding your concern. Please answer the following:
- What is the full make and model of your laptop?
- What is your current graphics driver version?
- Does the issue occur when you switch to a different KVM?
- Are you using the graphics driver provided by your laptop manufacturer? If not, have you tried rolling back to that version?
- If you recently updated your graphics driver, did you perform a clean installation?
- What is the model of your monitor?
- What display adapter are you using, and what is its version?
Also, to better understand your entire system information, please use the System Support Utility (SSU). This will generate a text file that compiles all your system information. You can follow this link for instructions and send the text file here: Help Guide for the Intel® System Support Utility
Dhanniel M.
Hello Dhanniel,
I tried to answer your questions as good as I know:
1. Fujitsu Lifebook U7512
2. Intel Iris Xe Graphics (driver version 31.0.101.5081)
3. Unfortunately I have only this one external KVM. With the internal KVM of my monitor I can choose the resolution 5120x1440
4. Yes, I think so...never changed it manually
5. I tryied to delete the graphics drivers and did a restart but it did not help
6. Philips 498P 32:9 ultra wide
7. I use the microsoft display drivers with version 10.0.19041.4355, could not find any drivers from philips
The requested scan with SSU is attached.
Some more obervations from my side:
If I switch back and connect my notebook direct to the monitor I can choose the resolution of 5120x1440 instantly as it worked all the time before.
The KVM switch itself does not really support this high resolution.
Obviously 32:9 is still a bit uncommon.
Nevertheless, on my other PC with a dedicated NVIDIA graphics card I first had the same problem, that I could not choose this high resolution together with the KVM. In the NVIDIA settings I could than easily set up the desired resolution manually and force the KVM to accept it, which is working fine.
So, I think the root cause is that 5120x1440 is not official supported by the KVM, nevertheless it seems to be possible (max is 3840x2160).
Is there any possibility to set the desired resolution manuelly with my internal Intel Chip?
I also tried to change the registry entry for the monitor but it did not help.
I would be very grateful a solution.
Thanks and best regards,
Lars
Hello Lars5,
I will check my resources to find a suitable solution for this issue. However, I need to clarify a few things first:
- Are you currently using an external KVM switch to connect your monitor to your laptop? If so, could you please provide me with the link or make and model of your KVM switch?
- When you mention using the built-in KVM switch before, do you mean it is built into your monitor?
Dhanniel M.
Hallo Dhanniel,
I am using a TESmart HKS0401A2U-EUBK.
Before I was using the built in switch of the monitor.
The problem becomes more weird to me:
I have a stationary PC and a Notebook which both were connected before to the internal switch of the monitor.
The PC was connected via a DP-Cable and the Notebook via a HDMI cable (let's call this cable type A).
Now both computers are connected via HDMI.
The PC is connected with a different HDMI cable to the switch and the switch with the same type of HDMI cable to the monitor (let's call this cable type B).
Now comes the weird thing:
Stationary PC is HDMI (B) to switch and HDMI (B) from switch to monitor and the resolution of 5120x1440 is working fine.
Notebook has HDMI (A) to switch and resolution of 5120x1440 is NOT working.
If i connect Notebook directly with HDMI (A) to the monitor as before the resolution of 5120x1440 is working as in the past.
But if I use HDMI (B) to connect the Notebook also directly to the monitor is it again NOT working.
Honestly I do absolutely not get, why it does not work on my Notebook with the other type of HDMI cable because the same cable works fine with the stationary PC.
Nevertheless I ordered another more expensive HDMI 2.1 cable which hopefully arrives soon.
HDMI (A) is definetly a 2.1 cable...(B) I'm not sure but I guess it is too, hence it works fine with the stationary PC.
But I'm also grateful for some other solutions.
Lars
Hello Lars5,
I appreciate your detailed explanantion of the issue. Let us do an initial troubleshooting by updating the graphics driver of your laptop. Please follow these steps for the clean installation of graphics driver:
Before you perform the clean installation first download the latest graphics driver (101.6078) from this link: Fujitsu Laptop Graphics Driver. Then let's perform the clean uninstallation:
- Disconnect from the internet to make sure the driver will not be automatically updated by Windows.
- Go back to the Intel Graphics entry in the Device Manager.
- Right-click Intel Graphics and click Uninstall.
- In the device removal dialog box, check Delete the driver software for this device and click OK.
- Restart the computer after the uninstallation is complete.
- Open the Device Manager.
- Expand the Display adapters section again.
- If no older drivers are stored in the system, the graphics controller in Device Manager should now be listed as Microsoft Basic Display Adapter, Standard VGA Graphics Adapter or similar. If not, repeat steps 2 through 5.
- Reboot the computer when prompted.
Execute Clean installation of driver:
- Click the .exe to initiate the driver installation.
- Agree to the Intel Software License Agreement.
- Click the checkbox to Execute a clean installation.
- A clean installation removes all old drivers and restores Intel settings to the default value
- Click Start to begin the install.
- Reboot the system if prompted.
If the above method cannot resolve the issue, try to use Display Driver Uninstaller to uninstall the graphics driver first, refer to:
How to Use the Display Driver Uninstaller (DDU) to Uninstall an Intel® Graphics Driver
Additionally, can you share the link of your External KVM. Then let me know if the outcome of following this troublehsooting.
Dhanniel M.
Hello Dhanniel,
I'm using a TESmart HKS0401A2U-EUBK as an external KVM swtich.
(https://tesmart.de/products/hks401-e23?srsltid=AfmBOoqRULgvn4T0BAN6GNUOG8s-YxKBEd_WpvA2JHB5NmSh9PiDizZg)
I did the clean reinstall of the drivers as you described but it did not solved the problem.
Also after reinstallation I was not able to set the desired resolution in the standard dropdown nor via the Graphics Command Center (Beta).
I also tried some different HDMI 2.1 cables just be sure but this did also not help or change anything.
Lars
Hello Lars5,
Thank you for performing a clean installation of the graphics driver. While reviewing your previous response, I noticed that you mentioned using HDMI Type B to connect your notebook directly to your monitor, which has an internal KVM switch.
Have you tried using HDMI Type B to connect your notebook to the switch, and then from the switch to your monitor? If so, does the resolution issue still occur?
Dhanniel M.
Hello Lars5,
I wanted to follow up on my previous question regarding this issue. Could you try using an HDMI Type B cable to connect your notebook to the switch, and then connect the switch to your monitor? If you've already done this, does the resolution issue persist?
Dhanniel M.
Hello Dhanniel,
I tried to change the HDMI cables in every possible configuration but unfortunately with the same bad result.
While all cables work fine directly connected to the monitor, with the switch in between I can not any more choose my desired resolution.
Is there any possibility to force the graphic card to use the higher resolution with the Graphics Command Center Beta?
Would you say that an EDID emulator could help?
Lars
Hello Lars5,
Thank you for sharing this information with me. Regarding your request for the EDID emulator, I will need to conduct an internal check for further investigation.
Dhanniel M.
Hello Lars5,
Thank you for your patience. Upon reviewing the specifications of the external KVM, it appears that the maximum supported resolution is 3840x2160 @60Hz with 4:4:4 chroma subsampling. Additionally, please note that Intel advises against using adapters, as they cannot guarantee compatibility or performance with third-party products.
If the issue persists, it might be due to the controller not supporting the adapter. In this case, I recommend contacting the KVM manufacturer, Tesmart, for potential solutions, as the integrated KVM seems to handle the resolution correctly. Here are some useful links for reference:
Regarding screen resolution, please verify your monitor's resolution settings, as the external KVM supports a maximum resolution of 3840x2160 @60Hz, which may not match your monitor's optimal resolution.
Dhanniel M.
Hello Lars5,
I am just checking to see if you happened to see my previous reply to this thread. I have provided the results of the investigation I conducted. Please let me know if you have contacted Tesmart regarding this.
Dhanniel M.
Hello Lars5,
Dhanniel M.
