652 Discussions
UHD 770, Directx 9.0c and ES: Oblivion
lauriest
Upon acquiring an HP g9 600 with UHD 770, surprised to find the Elder Scrolls: Oblivion is not showing any graphics with HDR turned on in Oblivion.ini with:
bDoHighDynamicRange = 1
Oblivion is a highly regarded game, and still played by many fans, and there are a ton of mods such as Oblivion Reloaded and OBGE that require functioning HDR.
There is this discussion on D3D9On12, could that be relevant, else any chance of bringing HDR to Oblivion?
RamyerM_Intel
Hello lauriest,
Thank you for posting in the communities. To check if the CPU you have supports HDR, may I please know the specific model? It would be much better if you can share with us the SSU logs as well.
I will be waiting for your reply.
Ramyer M.
RamyerM_Intel
Hello lauriest,
I am just checking in regarding my previous post. Feel free to reply back to us. I will be waiting for your reply.
Ramyer M.
RamyerM_Intel
Hello lauriest,
I hope you are doing well. As we have not heard a response in the past few days, we will proceed in closing this thread. Should you need assistance in the future, please submit a new question as this thread will no longer be monitored.
Ramyer M.
lauriest
Hi Ramyer,
Apologies for the mix-up, the last post was removed because of a One-Drive url.
CPU is 12th Gen Intel(R) Core(TM) i5-12500 3.00 GHz.
The SSU program did not work properly went it came to posting the data, and there seemed to be an issue with the attachment here, so if you still require the SSU report, it can be done internally or privately.
System Information report written at: 06/11/24 01:40:31
System Name: THATS-MY-DESKTOP
[Components Information]
Item Value
MEBx Version NA
FW Version 16.1.30.2361
LMS Version 2316.5.1.7
MEI Driver Version 2345.5.3.0
MEI DeviceID PCI\VEN_8086&DEV_7AE8&SUBSYS_8951103C&REV_11\3&11583659&0&B0
SOL Driver Version 2316.5.0.0
SOL DeviceID PCI\VEN_8086&DEV_7AEB&SUBSYS_8951103C&REV_11\3&11583659&0&B3
PMC Version 160.2.0.1043
Edit: The attachment worked here this time, so should be no problem.
