Why Framework Laptop i5 1340P
redscarelett
Hi
I have replaced the mainboard with a 13th generation processor. I did a clean install of Windows 11 and Framework bundle drivers. Then installed DSA software and updated graphics drivers. WOW that should not happen, Alchemist Graphic card is bigger than my mainboard. Intel Arc Pro 31.0.101.4955 has been installed. Could there be a long-term issue. I upload 2 text files SSU and Intel Graphic Commander. My dedicated graphic memory is 128 Megabytes. I do play games, 2 are DX-12 and 2 are DX-11.
Thank You
Regards Redscarlett
AlHill
Dedicated video memory means absolutely nothing.  Your graphics will allocate up to 50% of your system memory.
What is it exactly that you are trying to say?
redscarelett
When a failure occurs whom, would I have asked for help. Forums or Customer Service?
redscarelett
Since you failed to answer my question. Whom do I asked? Close this conversation. No Solution found.
AlHill
No, I answered your question about dedicated video memory.  I also asked you to clarify what your problem is.
If you cannot, then the issue is closed.
n_scott_pearson
So I read through this conversation and *still* don't understand what the actual question is. WOW, what shouldn't happen? What possible long-term issue?
Not that I understand what the 'bigger' comparison is actually trying to measure, but your 'graphics card' in this case is actually a combination of the graphics engine in the processor and circuitry on the motherboard that (eventually) presents you with DisplayPort, HDMI, VGA or DVI port(s).
P.S. Al is correct that the dedicated memory is only 128GB - and no, it cannot be configured to a higher amount. During runtime, based upon the demands of the graphics software (games, photo & drawing apps, etc.) running, the graphics driver will automatically allocate (up to a maximum of 50% of the (initially) available) system memory to use as VRAM. When demands drop, some or all of this allocated memory will be returned to the System pool, thereby making it available to support non-graphical operations.
