black bars cs2
fulldurakk
I recently got my asus tuf gaming f15  and intel uhd graphics  it works just fine with almost everything.
I have one little problem which is just my own preference but I would still like to get a solution for this.
My problem is the following:
I like to play CS2 with black bars but I just can't get black bars working for the game.
Every other game that I play on 4:3 has black bars but cs2 hasn't.
I tried everything I've read on the internet from trying with IGCC up to changing my native resolution for my monitor to a 4:3 resolution and maintaining the display ratio. But even then CS2 is fully stretched.
A little side fact because I read some answers hinting to the following: I can't change the settings for my monitor regarding stretched resolution or not stretched resolution.
Is there anything else I can try?
Does someone here with an Notebook with intel uhd graphics play CS2 with black bars?
Thanks in advance for your answers.
a1one
hi i also play cs2 normal 4:3 1280x960 getting average 80-90 fps.
do you have intel graphics command center?
go into display settings and change your monitor resolution to 4:3 display like 1280x960 or 1024x768.
then go to search bar and write intel graphics command center.
in command center go to display and change SCALE option to stretched
fulldurakk
On the contrary, I want to install black bars in cs 2 on the desktop, they are there, but when I go to the game, it itself stretches the image, but I want and am used to playing with black bars in Intel, I have the main aspect ratio
a1one
do you have monitor?
if then change from there
or use centered scrren ratio
umbr1X
