22966 Discussions
İNTEL HD GRAPHİCHS
Demır
i get this error i have no screen on my laptop monitor my driver and windows are up to date
Device PCI\VEN_8086&DEV_591B&SUBSYS_11AD1462&REV_04\3&11583659&0&10 had a problem starting.
Driver Name: oem86.inf
Class Guid: {4d36e968-e325-11ce-bfc1-08002be10318}
Service: igfx
Lower Filters:
Upper Filters:
Problem: 0x15
Problem Status: 0x0
AlHill
So the Intel support engineers can have more information about your system, Download, run, and save the results of this utility as a text file:
https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility
Then ATTACH the text file using the instructions under the reply window ( Drag and drop here or browse files to attach ).
Demır
sorunum hala devam ediyor laptop ekranımda görüntü yok hdmi ile televizyona bağlanıyorum
n_scott_pearson
According to the report, you have the correct version of the Intel driver installed. You have, however, installed a version of the NVIDIA driver that is beyond what MSI says you should be using. Download the 382.05 package (using link: https://download.msi.com/nb_drivers/vga/VGA_vga_Win10_x64_HDA(382.05)-1021493-01_22.21.13.8205_0x85d041be.zip) that MSI recommends and install it.
Hope this helps,
