23785 Discussions
1 fps error in games
erikgabriel
Hi, I'm having a problem with games crashing at 1 fps in the new intel hd graphics driver updates and would like to know if you can fix this.
my motherboard is made by: Dell Inc.
model: 06j0hf
Serial Number: /9BNY2T2/BRFCBO085700HV
my laptop model is a dell inspiron 15 3000 series, i15-3567-D10P.
my laptop has 3 to 4 years of use.
all the games I tried had the same error.  i tested gta v, valorant and fortnite.
I'm using Windows 10 pro, version 21H1.
the error happens whenever you open a game.
and attached a system report from intel ssu.
Sorry for typos as I'm using a translation service
megan3000
Valued Contributor I
Which "new Intel HD graphics driver"? You didn't mention what the driver version is... and the report actually shows you have a very old version... (22.20.16.4815)...
You should update only (or whenever it is possible as first try) to the drivers that your manufacturer provides.... the latest on Dell is 22.20.16.4836. I suggest you try that one...
Megan ❤️
megan3000
Megan ❤️
erikgabriel
this version of the driver installed is the version that i managed to make my intel hd work correctly but i will try to install that version you indicated. Thank you very much
erikgabriel
