22860 Discussions
4K@60Hz HDR playback over HDMI
OHøgb
Hi!
I`m looking for a NUC which are able to playback UHD/4K HDR content at 60Hz over HDMI. I`ve set my sights on the NUC7I5BNK as it has the needed HDMI 2.0a output for HDR. However this page https://ark.intel.com/products/97539/Intel-Core-i5-7260U-Processor-4M-Cache-up-to-3_40-GHz https://ark.intel.com/products/97539/Intel-Core-i5-7260U-Processor-4M-Cache-up-to-3_40-GHz says max resolution at HDMI 1.4 is 4K@30Hz. Is that the limitation if the input of your device is HDMI 1.4? Or is it the limitation for the NUC715BNK?
Does the NUC7I5BNK offer 4K@60Hz over HDMI, or are there other NUC`s better equipped for this task?
Hello smultring,
I understand you would like to know if the Intel® NUC NUC7I5BNK supports or not 4K@60Hz HDR playback.
Yes, the graphics controller that comes on the Intel® NUC NUC7I5BNK supports 4K@60Hz HDR playback through HDMI 2.0 and Displayport* 1.2.
The 4K@30Hz is just a limitation for HDMI 1.4. The Intel® NUC NUC7I5BNK comes with HDMI 2.0a port.
Let me know if you have or not any other inquiry.
Fred D.
Hello smultring,
Fred D.
