23850 Discussions
7463 Version Problem
agüle
Hello. When this update arrives I have installed it and this problem has appeared. The screen looks brighter than before when I load it. I'm back to the old version (7372). Does anyone else have this problem? I hope I'm not the only one. I hope it gets better
AlHill
What is the model number of your device/motherboard?
What version of Windows 10? 1903 (with all updates)? 1909?
Do you have dual graphics?
If you are a laptop, are you using the drivers provided by your laptop manufacturer?
Doc
agüle
-I check dxdiag but only my laptop model says. Is this the motherboard model number?
-1909 all updates
-2 graphics cards, yes Nvidia 1050 and İntel HD Graphics 630
-Yes I'm using
And laptop connected to external monitor HDMI TO DVI
1-)
Eray1
Open the Command Center and disable the all of the power saving options. On my laptop, colors get really dull when those are enabled.Annotation 2019-12-11 183654.png
agüle
I don't already have those options.
I will try to install the next update, maybe they'll fix it
thanks for your help
AlHill
Look on the bottom of the laptop. It will have the name of the manufacturer and the model number of your laptop. Then, contact them for support of THEIR laptop. This is especially the case since you have DUAL graphics. You may avoid a call with the manufacturer if you use the drivers from THEIR website for THEIR laptop.
Doc
agüle
NKN850HJ1007H00960
just writes this
agüle
I'm installing other programs from the monster site, except the graphics card,
Intel Chipset Driver, ME (Management Engine)
like.
But all of these things I've uploaded are old. I have been using 2 years, for the first time something like this happened
AlHill
Download, run, and ATTACH (using the paperclip) the results of this utility:
https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility
Doc
agüle
How do I send a txt file?
agüle
Is there any possibility of improvement with other future updates?
