23737 Discussions
A750 BlueScreen
Merle
blue screen happened while i playing game:我在地球修仙有系统.
i dont know whether it is a bug about A750 graphics.
dump shows:
Microsoft (R) Windows Debugger Version 6.6.0007.5
Copyright (c) Microsoft Corporation. All rights reserved.
Loading Dump File [C:\Windows\Minidump\092323-11312-01.dmp]
Mini Kernel Dump File: Only registers and stack trace are available
Symbol search path is: *** Invalid ***
* Symbol loading may be unreliable without a symbol search path. *
* Use .symfix to have the debugger choose a symbol path. *
* After setting your symbol path, use .reload to refresh symbol locations. *
Executable search path is:
* Symbols can not be loaded because symbol path is not initialized. *
* The Symbol Path can be set by: *
* using the _NT_SYMBOL_PATH environment variable. *
* using the -y <symbol_path> argument when starting the debugger. *
* using .sympath and .sympath+ *
Unable to load image ntoskrnl.exe, Win32 error 2
*** WARNING: Unable to verify timestamp for ntoskrnl.exe
*** ERROR: Module load completed but symbols could not be loaded for ntoskrnl.exe
Windows Vista Kernel Version 19041 MP (16 procs) Free x64
Product: WinNt, suite: TerminalServer SingleUserTS
Kernel base = 0xfffff801`6a000000 PsLoadedModuleList = 0xfffff801`6ac2a210
Debug session time: Sat Sep 23 08:37:23.952 2023 (GMT+8)
System Uptime: 0 days 11:33:50.737
Loading Kernel Symbols
Loading User Symbols
Loading unloaded module list
* Bugcheck Analysis *
Use !analyze -v to get detailed debugging information.
BugCheck 1E, {ffffffffc0000005, fffff801958f60be, 0, 4}
***** Kernel symbols are WRONG. Please fix symbols to do analysis.
*** Your debugger is not using the correct symbols ***
*** In order for this command to work properly, your symbol path ***
*** must point to .pdb files that have full type information. ***
*** Certain .pdb files (such as the public OS symbols) do not ***
*** contain the required information. Contact the group that ***
*** provided you with these symbols if you need this command to ***
*** work. ***
*** Type referenced: nt!_KPRCB ***
*** work. ***
*** Type referenced: nt!KPRCB ***
*** work. ***
*** work. ***
*** work. ***
*** work. ***
Unable to load image WUDFRd.sys, Win32 error 2
*** WARNING: Unable to verify timestamp for WUDFRd.sys
*** ERROR: Module load completed but symbols could not be loaded for WUDFRd.sys
Probably caused by : WUDFRd.sys ( WUDFRd+160be )
Followup: MachineOwner
please help with it.thanks!
Andres_Intel
Hello Merle,
Thank you for posting on the Intel®️ communities. As a gamer I know is very annoying to have Blue Screen of Death (BSOD) when playing a game, I am more than glad to help you.
To understand the issue in a better way, please answer the following questions:
Andres P.
Andres_Intel
Hello Merle,
Were you able to get the Intel® SSU report?
Andres P.
Andres_Intel
Hello Merle,
Andres P.
