显卡本身的风扇并不会转动
Hello jhhkg
请注意,我只能用英语为您提供支持 我使用了网络翻译工具来翻译此回复,因此可能存在一些不准确的翻译.
Thank you for posting on the Intel Communities. I am sorry you are experiencing issues when trying to monitor the fans from Intel® Arc™ Control Software.
The fans' RPM should show in the performance tab or also from the software overlay with ALT+O if the GPU is not experiencing high temperatures the fans will not spin. Starting with driver 31.0.101.4369 the Fan Control feature was added to the software, try to set a lower curve for the fans to start spinning at a lower temperature to verify and make sure the fans work.
In regards to the issue you mention about performance on a game, please open a new thread so we can do specific troubleshooting for that issue and gather more information from you.
Hugo O.
Hello jhhkg
I hope you are doing fine.
Hugo O.
Hello jhhkg
I have not heard back from you. So I will close this thread. If you need any additional information, submit a new question, as this thread will no longer be monitored.
Hugo O.
![](/skins/images/872293744008A34B36F8ABF94A46CC66/responsive_peak/images/icon_anonymous_message.png)
