23062 討論
A770 16G Apex legends 花屏问题
lydmq
初學者
26,419 檢視
在Apex legends游戏中出现花屏现象,尝试使用31.0.101.4952、31.0.101.4900、31.0.101.4887驱动版本都能有花屏现象。
具体视频:https://www.bilibili.com/video/BV1Ch4y1B7Gp/
0 積分
28 回應
Andres_Intel
員工
22,714 檢視
Hello lydmq,
Thank you for posting on the Intel®️ communities. I see the blurred screen problem in the video while playing Apex Legends with your Intel® Arc™ A770 Graphics in the video, I will be happy to help you.
请注意,我只能用英语支持你。我使用网络翻译工具翻译了此回复,因此可能存在一些不准确的翻译。
To have a better understanding of the issue, please answer the following questions:
Andres P.
lydmq
初學者
22,695 檢視
很高兴您回复了我,视频的情况是游玩游戏一段时候后导致的,开始时出现症状是游戏的技能出现颗粒感。
我正在使用的显卡:GUNNIRIntel Arc A770 Photon 16G OC W
我的游戏配置截图和System Support Utility:
I'm glad you replied to me. The situation in the video was caused by playing the game for a period of time, and the initial symptom was a graininess in the game's skills.
The graphics card I am using: GUNNIRIntel Arc A770 Photon 16G OC W
My game configuration screenshot and System Support Utility:
Andres_Intel
員工
22,656 檢視
Hello lydmq,
Thank you for your response and for all the information provided it has been really helpful.
I have seen the Intel® SSU report that the system is not fully up to date, please follow the steps below and let me know the results, since these updates may have fixes and improvements:
  • I see right now you are running the latest graphics driver available, to check if the behavior changes, clean install the graphics driver to version 31.0.101.4952 with Display Driver Uninstaller (DDU). For guidance, How to Use the Display Driver Uninstaller (DDU) to Uninstall an Intel® Graphics Driver.
  • Some days ago Microsoft released a new Windows 11 version, update it to version 23H2, if the previous step does not solve the issue. You can contact Microsoft for guidance.
  • Also, I noticed the BIOS is not in the latest version, it may have stability improvement that may help the graphics card performance, update it to version 7B89v2K. For installation steps, you can contact MSI
Andres P.
lydmq
初學者
22,632 檢視
你好!我已经更新系统到23h2版本,BIOS也已经最新,然后使用DDU卸载驱动后重新安装驱动31.0.101.4952 版本,还是会出现技能颗粒问题,而且我的帧数还出现不稳定的现象,在阳光下帧数会暴跌,我在最后上传了最新的ssu。
Hello!
I have updated the system to version 23h2, and the BIOS is also up to date. After uninstalling the driver using DDU and reinstalling the driver version 31.0.101.4952, there will still be skill granularity issues, and my frame rate is unstable. In the sunlight, the frame rate will plummet. I uploaded the latest ssu in the end.
我还发现如果把图形性能加速调至35以上会加速出现视频中画面撕裂问题。
I also found that if the graphics performance is accelerated to 35 or higher, it will accelerate the occurrence of image tearing in the video.
ARC88
初學者
22,618 檢視
Apex Legends is available with the Direct 12 API. It shows much better picture quality and performance than Direct 11. In the Steam library, right-click Apex Legends, click Properties, and then add the following command line to the startup argument.
-eac_launcher_settings SettingsDX12.json
lydmq
初學者
22,561 檢視
Hello !
I am currently using dx12. Both dx12 and dx11 have been used in the video, and there is a problem of image tearing in both cases.
Andres_Intel
員工
22,561 檢視
Hello lydmq,
Thank you for your answer and for completing the recommended steps.
Related to the to the frame issue to help you in the best way and keep this thread organized, since this is related to blurred screen issues with Apex Legends, please open a new thread for the other issue.
I will start with an investigation to provide you with the next steps, as soon as I have them, I will let you know.
Andres P.
Andres_Intel
員工
22,526 檢視
Hello lydmq,
Thank you for your time.
We still working on the investigation and now we have a question for clarification:
  • Are you running the game with DirectX11 or DirectX12?
Andres P.
lydmq
初學者
22,519 檢視
Hello, the longest I have been using is DirectX12, and after encountering issues, I tried using DirectX11 for a while, but the screen tearing problem still occurs.
Andres_Intel
員工
22,496 檢視
Hello lydmq,
Thank you for your clarification, that will help a lot.
Now I will continue with the investigation, as soon as I have the next steps I will let you know.
Andres P.
Andres_Intel
員工
22,476 檢視
Hello lydmq,
Thank you for your patience.
We have working on the investigation and now I have the following questions:
  • Was the issue happening on previous drivers?
  • Have you had this issue present before?
  • If it was working before, can we make sure there were no hardware or software changes?
  • Provide me with step-by-step instructions to replicate the issue, this will help us to replicate the issue.
Andres P.
lydmq
初學者
22,437 檢視
Hello, this problem has been occurring since I purchased and used the A770 graphics card on October 1, 2023.
Regarding the steps to reproduce: I get a grainy feeling when I enter the game, and then the screen tearing becomes worse after about 30 minutes of playing. In addition, if the graphics performance is accelerated and adjusted to 35 or more and the voltage is 105mV before the game, the screen tearing will be accelerated.
I didn't have this kind of problem when using Nvidia1660 graphics card before.
ARC88
初學者
22,434 檢視
I'm also playing Apex Legends using the A770 16GB card. Screen tear mitigation mode: Smooth sync has been set up and is in use without issue (GPU Load does not reach 99-100% perfectly, but most situations have usage around 95%. I think driver optimization will solve it.)
Anyway, return the 35 and voltage offset settings you put in the GPU Performance Boost to the default. This setting corresponds to an overclock, and if an unstabilized value is set, game operation may become unstable.
Andres_Intel
員工
22,407 檢視
Hello lydmq,
Now, I will start with the investigation and as soon I have the results I will let you know.
Andres P.
Andres_Intel
員工
22,285 檢視
Hello lydmq,
We have been working on the investigation and were unable to replicate the issue, we played the fire range game more, same character, and used the same ability, but the game worked flawlessly on our end. You can find the video below.
To check if you continue having the same behavior, please update the graphics driver to the latest version we released yesterday, by following the steps below:
  1. Clean install the graphics driver with DDU, as you did previously. If you need still guidance, on How to Use the Display Driver Uninstaller (DDU) to Uninstall an Intel® Graphics Driver.
  2. Install graphics driver to version 31.0.101.4953.
Let me know the results.
Andres P.
lydmq
初學者
22,269 檢視
Hello, I used DDU to uninstall and reinstall the latest driver, but the issue with pixel particles still persists. Could this be a hardware problem with the graphics card? Because I did not see the issue with pixel particles in your video.
I recorded a new video at the end.
Jamas94
新貢獻者 I
22,252 檢視
这有没可能是你超频的问题?,目前本身驱动就不是很稳定,超频本身不完善。
可变刷新率 intel 这边确实有问题,还是会有轻微画面撕裂
lydmq
初學者
22,208 檢視
显卡我没进行超频,我的内存频率4000MHz 时序17 21 21 56,然后R55600G超频了一些到4.62GHz,都跑过3Dmark压力测试。
Andres_Intel
員工
22,225 檢視
Hello lydmq,
Thank you for your keeping us informed.
To know if this is a hardware issue, overclocking issue and also to proceed with the next steps, I will continue with the investigation and I will be back as soon as possible.
Also, let us know if you have overclocked the graphics card.
Andres P.
lydmq
初學者
22,184 檢視
Hello!
After encountering the issue, I tried adjusting the graphics processing performance acceleration to 35 within ArcControl. However, I did not modify any graphics card parameters before the problem occurred.
As for other overclocking, I have overclocked the CPU to 4.62 GHz and the memory to 4000 MHz, but I have maintained these overclocked parameters without any corresponding issues before replacing the A770 graphics card.
回覆
