22649 Discussões
A770 Blackscreen while netflix/disney+ fullscreen
Nconstruct
Novato
849 Visualizações
I do encounter blackscreens when watching netflix or disney+ in fullscreen this problem does not occur when watching Youtube or Twitch. Through having another PC with same CPU but different GPU (without the blackscreens) I´ll guess it is a driver problem maybe with the video en/decoder ?
I really hope you can fix that.
Best regards.
3 Respostas
Jean_Intel
Funcionário
813 Visualizações
Hello Nconstruct
Thank you for posting on the Intel️® communities. We would be more than glad to help you.
To better assist you, we would like to check the following information:
  • When did the issue start?
  • Are you using a website or an application to watch the content (Netflix and Diney+)?
  • Is the Intel A770 the original graphics card in your system?
  • What Troubleshooting steps have you tried?
  • We would like to gather more information about your system, so please create a system report using the following tools:
  • Intel®️ System Support Utility (Intel®️ SSU)
    • Open the application and click "Scan" to see the system and device information. By default, Intel®️ SSU will take you to the "Summary View."
    • To save your scan: click "Next"; then "Save."
  • Intel® Graphics Command Center:
    • Open the Intel Graphics Command Center
    • Navigate to the Support tab
    • Select System Diagnostic
    • Click Generate Report
    • Select Save and name the output file.
Jean O.
Jean_Intel
Funcionário
800 Visualizações
Hello Nconstruct,
Since we haven't received a response, we want to know if you have been able to gather the information we requested. Remember that the details will help us to continue troubleshooting your issue more efficiently.
Jean O.
Jean_Intel
Funcionário
774 Visualizações
Hello Nconstruct,
Unfortunately, since we have not received a response in some time now, we will proceed to close this thread. Note that the information requested is important to better understand your issue.
If you need additional information, please create a new thread, as this will no longer be monitored by Intel.
Jean O.
Responder
