23269 Discussions
ARC A750 compatibility with 9th Gen?
Ac808
I was looking to upgrade my video card to an ARC A750 but found out you need rebar. I have an i7-9700k but, my motherboard has an option for rebar. Would the video card work if BIOS has the option?
Hugo_Intel
Hello Ac808
Thank you for posting on the Intel Communities. Thank you for your interest in our Intel® Arc™ GPUs, I will be glad to assist you with these questions.
We strongly recommend that your system supports resizable BAR, not having Resizable BAR enabled on the system could result in compatibility and performance issues. Check the following article for more information:
Do You Need a Resizable BAR to Use Intel® Arc™ Graphics?
We also recommend using the ntel® Arc™ GPUs in the 10th generation and above system, this does not mean the GPUs will not work in older generations, however, you might experience issues as well. You can find the official requirements in the following article:
Intel® Arc™ A-Series Graphics – Desktop Quick Start Guide
Hugo O.
Hugo_Intel
Hello Ac808
Were you able to check the previous post? Let us know if you have further questions related to this topic.
Hugo O.
Hugo_Intel
Hello Ac808
I hope you are doing fine.
I have not heard back from you. So I will close this thread. If you need any additional information, submit a new question, as this thread will no longer be monitored.
Hugo O.
