22831 ディスカッション
ARC A770 ERROR
ravenholm
ビギナー
3,527件の閲覧回数
Hi! I wanna show you sometimes what happen on my screen.  This happen sometmes when i watch streams on twitch or sometimes when in games i turn off the v sync. How can i slove this?
0 件の賞賛
6 返答(返信)
Andres_Intel
従業員
3,485件の閲覧回数
Hello ravenhol,
Thank you for posting on the Intel®️ communities. I see that you are having graphic corruption issues with your Intel® Arc™ A770 Graphics, I understand how frustrating this can be, I will be happy to help you.
To have a better understanding of the situation, please answer the following questions:
  • When did the issue start?
  • Did you make hardware and software changes? If so, which ones?
  • What ports are you using to connect the monitor?
  • Are you using a display adapter or docking station? If so, what is the make and model?
  • What is the power supply make and model?
  • What is the monitor's make and model?
  • Download, run, save and attach the report for the following tool Intel® System Support Utility for Windows (SSU) to check your hardware and system information, you can find the steps on the link How to get the Intel® System Support Utility Logs on Windows.
Andres P.
ravenholm
ビギナー
3,478件の閲覧回数
Hi. I try to tell you what i know.  At last time: i turn on twitch (from opera browser) for world of tanks dropps.  And in the same time i play games like world of tanks or fallout 76.  And i randomly check the drop progress.  And at this time happened when i press the windows key for put down the game window for switch to opera.  (+ on world of tanks can happen when i turn off the v sync. ) i dont change anything.  Im use hdmi cabel. My monitor is asus vg245h.  psu seasonic b12 bc-750
i dont use any display adapter or docking station.
im updated my vga driver for the lastest version after my first post.
Andres_Intel
従業員
3,472件の閲覧回数
Hello ravenhol,
Thank you for your response, all the information provided has been really helpful.
Please follow the steps below and let me know the results:
Andres P.
Andres_Intel
従業員
3,400件の閲覧回数
Hello ravenhol,
Were you able to clean install the graphics driver to version 31.0.101.4578 and version 31.0.101.4644?
Andres P.
Andres_Intel
従業員
3,348件の閲覧回数
Hello ravenhol,
Andres P.
JuanH1
ビギナー
2,339件の閲覧回数
Buenas, eh tenido recién este problema con mi portátil no se si sea la gráfica del procesador o que sería? Por qué juego y avances pasa eso y se crashea todo y la dejo descansar pero eso ya me empieza a preocupar
返信
