Hi,I found there are some mistakes in playing Tomb Raider 9 with Arc B580. The fps would decresing so fast from 217fps to 54fps when I use tressFX in hair setting!!.Could you solve this problem?.
1.Maxsun OC 12GB B580
2.Game is coming from Steam
3.this problem is stable
4.I perform DDU when updating to driver version 32.0.101.6557.I always do in this way.
5.setting is 2560x1440P,highest setting.
I attach two capfamex.json.One(08T0623) is the 217fps result without tressfx,other one(08T089) is the 54fps result with tressfx.
- Tags:
- Arc B580
Hello Sean2025,
We have a documented comment or resolution in our website. Please check the link below:
https://www.intel.com/content/www/us/en/support/articles/000097953/graphics.html
As stated, you may contact the appropriate owner to report this issue.
Michael L.
Hello Sean2025,
Thank you for understanding.
Since I already answered your inquiry, I need to close this inquiry.
Michael L.
