22649 Discussions
ARC750 compatibility with DXO DeepPrime XD
GWR52
Débutant
20 015 Visites
Just installed my new ARC750 and have updated the drivers to 31.0.101.4369 and was  wondering if it is a known problem or are there are any other users having issues with DXO photolab 6 elite.
When using the DXO noise reducing technology  DeepPrime XD to process RAW files,   the review and output both generate a small pixelated area rather than an image when using the Intel GPU to process the image. If the GPU function is turned off and the image is rendered using CPU only then there are no issues other than processing takes 20x longer.
As this functionality previously worked using a sapphire RX480 nitro would this be being caused by an Intel driver issue?
System: Win11 Pro, AMD 5700x, 32GB ram, ARC750
0 Compliments
29 Réponses
Jean_Intel
Employé
15 744 Visites
Hello GWR52,
To better assist you on this matter, we would like to request the following information:
  • You mentioned having tried a Sapphire RX480 nitro. Therefore, we would like to know if you tried this card on this system. Or is the Intel® Arc™ A750 the original graphics adapter on your system?
  • This issue is only present when using the noise-reducing technology DXO DeepPrime XD, correct?
  • Is Smart Acess Memory enabled on your motherboard BIOS?
  • Can you share a screenshot of the problem you described?
  • Also, we would like to ask for more system information. Please, create a system report using the Intel®️ System Support Utility (Intel®️ SSU)
    • Download the Intel SSU
    • Open the application and click "Scan" to see the system and device information. By default, Intel®️ SSU will take you to the "Summary View."
    • To save your scan: click "Next"; then "Save."
    • Attach the saved file to your next response.
Jean O.
0 Compliments
Vast-Squirrel
Débutant
15 739 Visites
Yeah, this doesn't work with the A770 either. I've talked to DxO about this and they think it is a driver problem with the Intel. Presumably they are talking to Intel about it but I don't know that for sure. They haven't closed my ticket so I assume they are still on it.
Edit: Although I will note that Intel Arc Control thinks I'm on 4314 and Support and Driver assist thinks that I'm on 4382. So god only knows what I have installed.
0 Compliments
GWR52
Débutant
15 716 Visites
In answer to your questions.
The  Sapphire RX480 nitro card has been in my system from day 1 and I have been using it with DeepPRIME XD from the feature's  release date.
According to DXO the RX480 was below minimum specification  and this was the reason I have upgraded to an ARC750 in hope of future proofing and to improve process times.  .
I enabled resizeableBAR (SAM) in BIOS before I installed the new ARC750 card into my system this week.
Files attached:
Screenshots of DXO screen showing part of the image and the Prime preview window when using: Prime, DeepPrime and DeepPrime XD options.
DeepPrimeXD.jpg is a copy of the full image when exported to Lightroom. This image matches the preview in the screenshot
GWR52 SSU.txt as requested.
 The LargeMemoryRange image confirms that Smart Acess Memory is enabled on the motherboard.
Many thanks
0 Compliments
Jean_Intel
Employé
15 730 Visites
Hello Vast-Squirrel,
Thank you for jumping in the thread to share your experience. We would like to further investigate this matter. However, we would like to wait for the information from GWR52, and if you want, you can also share the information we requested from your end. The more information we have, the better.
Jean O
0 Compliments
Jean_Intel
Employé
15 658 Visites
Hello GWR52,
Thanks for the information provided
Since you mentioned that you upgraded your Sapphire RX480 nitro to an Intel® Arc™ A750, we recommend you run the DDU tool to eliminate all the driver files leftovers from the previous driver version and leftovers from drivers from your previous graphics adapter. Once you run the tool, you should install our latest BETA driver, 31.0.101.4382. Files from earlier installations of drivers can linger on a system which can cause driver updates to not work as expected.
Jean O
0 Compliments
GWR52
Débutant
15 650 Visites
Used DDU as suggested and have installed latest Beta 31.0.101.4382 but the problem remains.
Rgds
G
0 Compliments
Jean_Intel
Employé
15 624 Visites
Hello GWR52,
Thanks for the informaiotn provided.
We will look further into this scenario, and we will back as soon as we have further details.
Jean O
0 Compliments
Jean_Intel
Employé
15 606 Visites
Hello everyone,
After taking a look at this issue, we would like to request a description of the step-by-step you follow to encounter this problem for issue reproduction purposes. It would be ideal if you can share a picture you confirmed that presents the problem and a video showing the steps and the issue.
Jean O
0 Compliments
GWR52
Débutant
15 588 Visites
As requested I have outlined the Process steps shown in the attached video.
Open DXO Photolab 6 Elite (PL6)
Set DXO preferences for Performance  to use either Auto or Intel®Arc™ A750 Graphics
Choose any RAW image from the filmstrip
Open DXO Denoising Technologies menu
Use the target to select preview area of image shows results prior to full image processing
4 denoise options:          High Quality /  PRIME / DeepPRIME /
Note: The results give increasing noise reduction levels and are shown in preview window
You may/will observe that the first 3 options will show increased  levels of noise reduction
However DeepPRIME XD will always show when using the GPU either a black preview or  pixellated colour bands depending on the preview area chosen.
Having chosen the denoise required I would select the Export to Lightroom option
Then chose the options from the menu  I would choose DNG and then select Export button.
DXO will then process the full image, with progress shown by the spinning indicator on the filmstrip.
If successful (10-15secs) there will be a Green Tick and the image will be exported to Lightroom Classic(LRC).
If LRC is not running this will cause LRC to open and then import and display the image. Note the last image the user viewed will initially display but will be replaced by the imported image.
Exports of all 4 denoise options will result in a full size image which will match the characteristics of the preview.
If you change the PL6 preferences / Performance option to “Use CPU Only” then DeepPRIME XD will preview and process the image correctly albeit the process time may now exceed 3 minutes per image as against 15secs utilising the GPU as as such not a viable option for general use.
Note: My previous Sapphire RX480 Nitro GPU did not exhibit this issue with DeepPRIME XD.
George
0 Compliments
Jean_Intel
Employé
15 562 Visites
Hello GWR52,
Thanks for the inforamtion provided.
We will resume our investigation on this matter with the new information. We will be back as soon as we have further details.
Jean O
0 Compliments
Jean_Intel
Employé
15 067 Visites
Hello GWR52,
After researching this problem, we would like to inform you that we have been able to replicate the issue internally. Our driver debug team has been notified and is currently investigating the matter. We appreciate your efforts in reporting this to us and apologize for any inconvenience caused.
We cannot provide an exact timeframe for a resolution, but please be assured that we are working on resolving this issue. We will update this thread with more information as soon as it becomes available.
Jean O
0 Compliments
cybertec69
Débutant
14 922 Visites
I have the same problem with DXOPhotolab6 and the Intel ARC 770 16 GB GPU, running a brand new PC with the Intel i7-1270K. The only way to export a file from DXO to Affinity Photo for further processing I can only use the CPU to do all the work, which not only stresses the heck out of the CPU but the process takes three minutes plus, a process that should not take longer than forty to sixty seconds when both the GPU and CPU are utilized by the DXO software. Once in Affinity Photo the software is set to use the ARC GPU which it does with no issues. The issue seems to be with DXOPhotolab6 and the ARC drivers, when I set the preferences to auto "which uses both the CPU and GPU the export comes out a black box, all the data seems to be missing, same if I only choose the GPU in the DXOPhotolab6 preferences, when I choose only the CPU to do all the lifting, the export comes out just fine, but it takes forever and it is stressing the heck out of the CPU.
This is unacceptable for a card that should be able to eat tasks like this for breakfast with no sweat. It's like being handed a race horse that was tranquilized. This horse should have never left the stable. I don't play video games, my PC is specifically used for photo and video editing and your other everyday tasks, browsing the web, email and the sort.
On another note, the UHD770 GPU build into the i7-1270K has the same issue as the ARC GPU. So this seems to be an Intel GPU "across the board" driver issue. I also have a laptop with an Nvidia GPU and Intel CPU and all my programs work as they should, including DXOPhotolab6.
This is becoming extremely frustrating to say the least. This issue needs to be fixed ASAP.
0 Compliments
cybertec69
Débutant
14 471 Visites
Still have issues. I posted this in the DXOPhotolab support email I had opened up with them.
This is an update from my previous posts. Intel came out with a new driver 31.0.101.4577 released on 07/24/23. I installed it, and now in the DXOPhotolab6 Preferences/Performance I can check the Enable OpenCL box and choose the Intel Arc A770 GPU under Deep Prime Acceleration. DXO noise reduction works only up to Deep Prime, once I choose Deep Prime XD "the preview box goes black " which is the latest version that came out with DXOPhotolab6, and the file export comes out corrupt/black.
I am adding screen captures of the issue I mentioned in my previous post. As you can see in the last screenshot the preview box goes black when choosing DXOPimeXD. And the export comes out the same, just a black box.
With DXO Deep Prime "image 5" the export comes out fine, with DXO Depp Prime XD the image "image 6" export comes out black, same black image as in the DXOPhotolab6 preview window when selecting DXO Deep Prime XD.
0 Compliments
cybertec69
Débutant
14 260 Visites
Update on my previous posts, this issue with DXO Prime XD "the other three DXO Prime noise reduction settings from high quality, prime and deep prime work just fine with the ARC A770 GPU" issue seems to be only happening with the Intel ARC A770 16 GB GPU when choosing DXO Deep Prime XD, when choosing Intel UHD 700, which is integrated into the CPU all four DXO Prime noise choices work just fine, including DXO Prime XD, but when processing a file in DXO with DXO Prime XD using the UHD 700 GPU the process is painfully slow, it takes between 2 and 3 minutes, most of the time closer to 3 minutes to export a file. Is it possible to give me an estimate in when this issue will be fixed. Thank you.
I also posted the above post in my open DXO support issue ticket. But this issue seems to be an Intel driver bug. I have also posted numerous other comments in this thread with no response from anyone from Intel.
0 Compliments
cybertec69
Débutant
14 136 Visites
This is an update from my previous posts. Intel came out with a new driver 31.0.101.4644 released on 08/11/23. I installed it, and now in the DXOPhotolab6 Preferences/Performance I can check the Enable OpenCL box and choose the Intel Arc A770 GPU under Deep Prime Acceleration. DXO noise reduction works only up to Deep Prime, once I choose Deep Prime XD "the preview box goes black " which is the latest version that came out with DXOPhotolab6, and the file export comes out corrupt/black.
0 Compliments
cybertec69
Débutant
14 177 Visites
I still have the same issues with the most current Intel GPU drivers.
This is an update from my previous posts. Intel came out with a new driver 31.0.101.4644 released on 08/11/23, and the issue persists.
0 Compliments
cybertec69
Débutant
14 745 Visites
Update on my last post. I posted this in the DXO support page. Hope this helps out both driver teams at Intel and DXO.
 As you can see the CPU is running at full throttle all 12 cores being utilized to their max and are burning up, reason is the Intel GPU is not being utilized as it should be, matter of fact it's not being utilized at all, it might as well not be installed on the motherboard. The ram 64 GB DDR5 4800mhz is also running hot.
First screenshot with PC in normal mode. Second screenshot with DXO processing the RAW file using only the CPU "the GPU can not be used". Third screenshot is the Performance/Preferences window, it says that unsupported GPU's will automatically be disabled "looks like both the Intel ARC 770 and the UHD 770 are not supported, which makes no sense", the enable OpenCL box is grayed out. Fourth screenshot is the time it takes for the RAW file to be processed, some take longer than others depending on the data in the file, as you can see it took six minutes for the file to be uploaded to AF2 as a TIFF, which should take between 40-60 seconds max if the GPU was able to be utilized. Once in Affinity Photo2 "fifth screenshot" the Intel ARC 770 or the UHD 770 both work as they should.
The last screenshot is what the file looks like when trying to use the GPU in DXOPhotolab6 after it is exported to AF2. As you can see it's just a black box, all the data missing, since DXOPhotolab6 is not recognizing the Intel GPU/GPUs.
Hope this helps out, and gets resolved as soon as possible. I will also furnish all this information to Intel in their Intel forums support page.
I don't care how wonderful the specs are regarding the hardware, regardless of industry, if the software is dodgy, or lacking, it will literally destroy your product. And with that your reputation, and with that, that product line. Especially if the hardware has been on the market for a year plus, give or take. Intel, are you listening.
CPU running at idleCPU running at idleCPU running like a banshee trying to process the fileCPU running like a banshee trying to process the fileDXO Performance panel shows the the Intel GPUs are not supported, which makes no senseDXO Performance panel shows the the Intel GPUs are not supported, which makes no senseThe time it took for the TIFF file to be exported to AFP2, which should take less than one minute if the GPU was utilized, which also would cause less strain on the CPUThe time it took for the TIFF file to be exported to AFP2, which should take less than one minute if the GPU was utilized, which also would cause less strain on the CPUAFP2 Performance panel shows that both the Intel GPUs work and are supportedAFP2 Performance panel shows that both the Intel GPUs work and are supportedThis is what it looks like trying to export from DXO to Affinity Photo 2 using the GPU, all the data is missing. Since the Software does not recognize the GPU.This is what it looks like trying to export from DXO to Affinity Photo 2 using the GPU, all the data is missing. Since the Software does not recognize the GPU.
0 Compliments
GWR52
Débutant
13 951 Visites
Just received the following update from DXO support:
 "The issue will be fixed in one of the next public releases. I was just provided this information."
DxO Labs Support Team
So fingers crossed that somebody will fix it, but still no idea of the timescales!
George
0 Compliments
cybertec69
Débutant
13 491 Visites
"Just received the following update from DXO support:
George"
I received pretty much the same message. It's a waiting game now.
0 Compliments
cybertec69
Débutant
13 425 Visites
DXO came out with an update today 09/01/23 for DXO PhotoLab6, but the issue I mentioned above still persists with the ARC A770 16GB GPU, still looks like an Intel software bug issue, the last Intel update for the ARC GPU's was on 08/11/23 hope the next update will resolve this DXO and DXO Deep Prime XD issue with the Intel ARC A770 GPU, the Intel UHD  770 GPU does not have this issue.
0 Compliments
Répondre
