- Als neu kennzeichnen
- Lesezeichen
- Abonnieren
- Stummschalten
- RSS-Feed abonnieren
- Kennzeichnen
- Anstößigen Inhalt melden
It's should related about monitor and graphic card issue, if you have related experence, kindly share knowledge about it.
When you open graphic setting in windows, you will find setting as below, what does it mean for disconnected with the monitor?
What's the difference between previous setting with Fn+P? Thanks.
Link kopiert
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
Hello WishStar,
Thank you for posting at Intel Community Forums
For me to properly address your concern, please translate the screenshots in English as I can only support with this language.
Once I have a better understanding of your concern, I'll be able to address it properly.
We hope to hear from you soon!
Jed G.
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
Hello WishStar,
I wanted to follow up to see if you had a chance to look over the information I posted. Your feedback at your earliest convenience would be greatly appreciated so we can move forward with resolving this matter.
Jed G.
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
I am sorry for my late reply.
Update the screenshot like below
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
Hello WishStar,
Thank you for your effort
I would just like to clarify your concern, do you like to know what is the function of the feature "disconnect this display"? Or do you just want to know if there is any difference between setting it up manually on display settings and using the shortcut Win+P?
I'm looking forward to your response.
Have a good one and stay safe!
Jed G.
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
Yes, I want to find the difference between display setting and using the shortcut Win+P. Thanks.
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
It is just the same. Win+P is just a shortcut to switch between displays
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
Thanks, after test there are one condition, when I duplicate mode with project, sometimes the display will not be the same. Although I am not sure the root cause is the Adapter or not, I use one adapter to connect with monitor and projector. (I mean there are three same display content by laptop monitor,projector, and another viewsonic monitor)
- Thema als neu kennzeichnen
- Lesezeichen
- Abonnieren
- Drucker-Anzeigeseite
