22655 討論
Acer Aspire AM3970G-UW10P How to run onboard video and video card
IZito
初學者
1,979 檢視
Hello
I Have this PC Desktop: Acer Aspire AM3970G-UW10P
Acer Desktop PC AM3970G-UW10P (PT.SJVP2.001) Intel Core i5 2320 (3.00 GHz) 8 GB DDR3 1 TB HDD AMD Radeon HD 7530M 1GB
And I want to connect video card onboard and video card But also HDMI and VGA connection on board who are not working
Someone please help me? I want to connect three monitors to your computer.
Thanks!
0 積分
1 回應
員工
1,139 檢視
Hello ItayZ,
Thank you for contacting the Intel community.
Please bear in mind that your best support is with your computer manufacturer, in this case you computer manufacturer is Acer as they are more familiar with your system and how all the components interact with each other.
Based on the processor model, this processor only supports 2 displays as you can see here:
http://ark.intel.com/products/53446/Intel-Core-i5-2320-Processor-6M-Cache-up-to-3_30-GHz http://ark.intel.com/products/53446/Intel-Core-i5-2320-Processor-6M-Cache-up-to-3_30-GHz
If you have a video card installed in most of the systems you will need to use the onboard video or the video card but you cannot use both, you can check in the BIOS if there is a setting to set it to work as the secondary adapter for multi-monitor support. I suggest you to confirm this with your computer manufacturer.
Ivan.
回覆
