23263 Discussions
Application and the use of driver software
clipnote
On my Lenovo computer with Windows 11, there are currently 3 areas for processing and applying settings in the graphics layer. They consist of integrated Intel graphics from the same manufacturer and provider of the software.
Of course, all 3 are up to date. The process runs automatically in the background or after manually searching for a new version. Whoever searches for updates faster: the computer or I 😛
My question now relates to the usefulness and purpose of the 3 "control areas."
Can or may one delete a control area without affecting the processor and the graphics card? I believe that sometimes even some drivers are installed twice as a result.
Windows 11 also offers me additional optional updates for drivers in this area. These are also brought up to date.
One would expect that the computer with the system and software recognizes this when the current and equally uniform driver has already been installed. However, this is not a hassle for me and can be done easily when I have time.
Which control areas can I delete? What is optimal and best in this field? Should I delete one of them, two of them, or none of the 3? 😕
Attached is a picture showing which 3 areas I mean and currently have. I would appreciate a professional answer. Best directly from an Intel specialist in this field.
Labels (2)
RobbieR_Intel
Hello clipnote,
Thank you for reaching out. The Control Areas mentioned would be the Intel Driver & Support Assistant, Intel Graphics Command Center, and Intel Graphics Software.
Here's how these software components function and their purpose.
Intel Driver Support & Assistant (IDSA):
This tool helps you detect and install the latest drivers for your Intel hardware, including graphics. It is primarily used for maintaining your system with up-to-date Intel drivers.
Intel Graphics Command Center:
A legacy interface allowing you to configure display settings, manage custom profiles, and optimize application for Intel graphics. It provides a visual and interactive way to adjust your system's graphics performance.
The latest and most feature-rich platform, combining optimization, driver management, and performance tuning.It replaces older tools like Arc Control and Intel Graphics Command Center.
My recommendation is to keep Intel Graphics Software, as it is the newest platform with comprehensive features, including seamless optimizations, detailed display options, and performance monitoring. While you can safely uninstall the Intel Graphics Command Center if you are using Intel Graphics Software, as it consolidates its functionality. Lastly, you may retain IDSA if you prefer automatic updates, but if you prefer to update your drivers manually, you may remove it.
Since you're using a Lenovo computer, it's important to verify driver compatibility. Lenovo often customizes drivers for their systems to ensure optimal performance and stability
You may check ⁠Lenovo's Support Page for graphics drivers tailored to your system.
If you prefer using the latest Intel drivers, ensure they're compatible and note that some features or optimizations may differ.
For more information, please see the following links below:
Intel® Graphics Command Center – Frequently Asked Questions
Intel® Driver & Support Assistant FAQ
Intel® Graphics Software
If you have further questions, kindly let me know.
I look forward to your response!
Robbie R.
clipnote
Many thanks for the reply.
Best Regards, Patrick
RobbieR_Intel
Hello clipnote,
I hope that I was able to answer your question. With that being said, do you need further assistance?
Robbie R.
RobbieR_Intel
Hello clipnote,
I wanted to follow up to see if you had a chance to look over the information I posted. Your feedback at your earliest convenience would be greatly appreciated so we can move forward with resolving this matter.
Robbie R.
RobbieR_Intel
Hello clipnote,
Robbie R.
