21094 Discussions
ArmA 3: DXGI_ERROR_DEVICE_REMOVED seems driver related
ICust27
Ever since ArmA 3 was released as an alpha back in March, it plagued me (and quite a few others) with these apparently random DirectX 11 crashes (either freezing or CTD):
"D3D Error - DXGI_ERROR_DEVICE_REMOVED"
"Display Driver Stopped Responding and has recovered."
A few days ago I, acting on a hunch, installed an old driver (15.28.7.64.2867) from October(?) 2012 and was able to play the game without any crashes in area's/maps that were unplayable before.
Working my way up (I have some, but not all drivers released) I found that the drivers up to 9.17.10.2932 (December 2012) perform flawlessly, while 9.18.10.3071 (March 2013) and later tend to suffer from this issue.
So while installing the latest drivers is recommended as a starting point for every glitch, in this case it is not going to get you anywhere: it seems that every iteration has inherited a flaw that was introduced somewhere during that period (December 2012 - March 2013).
I hope this in some way helps you to tackle this issue, and allows me to have my graphics driver up to date in the near future...
These 'tests' were performed, ceteris paribus, on this machine:
Intel i7-3770K@3500|3900 (HD 4000@1150)
MSi Z77A-GD65 (UEFI: 10.11ß)
32GB Corsair Vengeance@1600
Windows 8.1_x64
All drivers were up to date.
Bryce__Intel
baboul Beelzebassie MrRexeh Scatches
All,
Could you uninstall the Intel graphics driver, retest this and provide your results?
We're now seeing the failure on a GT3 configuration in windowed mode without the Intel driver installed. This indicates this is not an Intel Graphics issue but perhaps an app issue. I'd like to confirm you're seeing the same thing.
ICust27
I'm not entirely sure what you're asking from me:
How am I going to test ArmA 3 without a driver installed?
At this moment I'm running driver version 4252 (W10_x64), which shows exactly the same behavior as I stated in the opening post.
I have no idea how this can not be a driver issue when drivers older than - and including - 2932 work perfectly while all newer drivers crash within minutes, ceteris paribus.
That said, I'd be more than willing to provide information about the crashes I encounter, problem is I'm not provided with the tools to produce decent debug information..
Bryce__Intel
Thanks for responding Beelzebassie
The Developer said they uninstalled the Intel driver so only the Microsoft default driver was present then rebooted and verified the Intel driver was still not present. They played the game and were still able to see the issue.
I don't have a failing system in front of me to try this. Could you offer any information if these same steps produce the same result for you?
If this fails with the BDA instead of the Intel driver, then it is most likely an OS or game issue. If it was resolved using a previous Intel driver, then we may have had a workaround that had fixed it accidentally or purposely that was since removed or broke. The underlying thing I need verified is if it truly fails without our driver installed. We can go from there.
ICust27
QUICK UPDATE:
While 'playing' (more like a 1FPS slideshow) for approx. one hour using the standard Windows driver no error did occur.
Installed Intel driver 4276ß, driver crashed within 5 minutes. (The 'Tipping Point' campaign mission will crash before your character reaches the rendez-vous point.)
Also with a clean Windows boot (minimum services/processes) the behavior persists.
PM2
Hello, I recently bought ARMA 3 and appear to be another Intel user plagued by this issue.
Namely unavoidable repeating game crashes/freezing at specific points that make missions incompletable and frequent random crashes that make ARMA 3 barely playable in general.
In answer to your question:
With the default Microsoft Basic Display Adapter driver instead of the Intel driver I am able to complete "Damage Control", the last mission of the "Prologue" campaign in the "Learn" menu (though at 1-3 frames per second and most of the audio out of sync).
With Intel's driver ARMA 3 crashes/freezes for me a little before/as/or a little after you land in the helicopter on the outskirts of the town (the exact time depends on graphics settings).
ICust27
Could you provide us with the Windows and Intel driver version used?
Cesar_B_Intel
Hello g8czfw
Could you please provide the information Beelzebassie requested at your earliest convenience?
Caesar B.
KJesp
I downloaded the 2932 driver, but when I want to download it mannualy I cant see it in the list
Cesar_B_Intel
Hello KoningJesper,
I noticed you are using the option that states "Let me pick from a list of device driver on my computer". In this particular case your should select the "Browse" option in order to open the "Browse for folder" option where you could let Windows know where your driver(*inf) path is located on your computer.
Please try this method and let me know of the results.
Caesar B_Intel
*Other names and brands may be claimed as the property of others.
HEarl
My game also used to hang in the prologue mission "Damage Control" when you're in the helicopter. It would hang right about when Adam says "Look there". It also hanged in another mission, which I can't seem to remember, it was about a year or so ago. I got through it by installing version 9.17.10.2932 of the driver. But the performance was really low with that driver. I just found this thread so I'm downloading the game again to provide any info you may need. I'm posting the 'Default Level Information' below.
Category
Questions
Answers (N/A if not applicable)
Description
Provide a detailed description of the issue
Game hangs when riding the helicopter in the prologue mission "Damage Control", when Adam says "Look there".
Does it fail every single time, or only sometimes?
If you can offer a % rate please do.
Everytime
Hardware (HW)
Brand and Model of the system.
Lenovo G580
Hybrid or switchable graphics system?
ie Does it have AMD or NV graphics too?
No
Make and model of any Displays that are used to see the issue (see note2 below).
LFP = Local Flat Panel (Laptop panel)
EFP = External Flat Panel (Monitor you plug in)
LFP, I can't seem to find it's name, but the serial number is 'CMO15a7'
How much memory [RAM] in the system (see note2 below).
4.00GB
Provide any other hardware needed to replicate the issue.
ie: Cables&brand, cable type [vga, hdmi, DP, etc], dock, dongles/adapters, etc
None
Cesar_B_Intel
HelloMeinWasser,
Are you attaching the Laptop to a TV?
I noticed Monitor Model: unknown which seems to be a TV/monitor attached to laptop and thus It requires a driver installation which could be found at the manufacturers website.
Please try uninstalling current Intel® Graphics driver and then installing https://downloadcenter.intel.com/download/25313/Intel-HD-Graphics-Driver-for-Windows-7-8-1-10-3rd-Gen-BYT- Download Intel® HD Graphics Driver for Windows® 7*, 8.1*, 10 (3rd Gen & BYT) if issue persists try http://support.lenovo.com/cr/es/products/laptops-and-netbooks/lenovo-g-series-laptops/lenovo-g580-notebook/downloads/DS037352 Laptops and netbooks :: Lenovo G Series laptops :: Lenovo G580 Notebook - Lenovo Support (US)*
Caesar B_Intel.
HEarl
Hi Cesar!
No, it's not attached to any external monitor/TV, only the built-in display.
I tried uninstalling the current driver, the Monitor Model was still 'unknown', installing the driver in the first link you posted, the Monitor Model was still unknown, uninstalled it and installed the driver from Lenovo's website, the Monitor Model was still unknown.
But I remembered seeing the monitor name in MadVR (a video renderer) settings: Chi Mei N156BGE-L21 CMO N156BGE-L21
Also, in each step above, I checked ArmA 3. With Microsoft's Basic Display Driver, the game didn't crash or hang in the Damage Control mission or anywhere else, but the performance was awful (2-5 FPS). With the driver from the first link, it crashed as usual. With the driver from Lenovo's website, it also crashed like before.
It works flawlessly with driver version 9.17.10.2932, but the performance, again, is very awful (but better than Microsoft's driver. About 10-15 FPS on the lowest settings, 720p).
So it seems the issue is Intel Graphics specific, with all drivers after 9.17.10.2932 crashing.
ICust27
HEarl
Hi Cesar!
Sorry for the very late reply! The driver in your link still crashes the game. 😕
Cesar_B_Intel
Hello MeinWasser and Beelzebassie,
Could you please provide your http://www.intel.com/content/www/us/en/support/graphics-drivers/000005848.html?wapkw=graphics+driver+report Intel® Graphics Driver Report for Graphics Drivers after you updated to latest suggested graphics driver?
Caesar B_Intel.
ICust27
Report for 4338:
Intel(R) HD Graphics 4000
Report Date: Tuesday, January 12, 2016
Report Time [hh:mm:ss]: 9:58:34 AM
Driver Version: 10.18.10.4338
Operating System: Windows* 10 Pro (10.0.10586)
Default Language: Dutch (Netherlands)
Installed DirectX* Version: 12.0
Supported DirectX* Version: 11.0
Shader Version: 5.0
OpenGL* Version: 4.0
OpenCL* Version: 1.2
Physical Memory: 32455 MB
Processor: Intel(R) Core(TM) i7-3770K CPU @ 3.50GHz
Processor Speed: 3500 MHz
Vendor ID: 8086
Device ID: 0162
Device Revision: 09
* Processor Graphics Information *
Processor Graphics in Use: Intel(R) HD Graphics 4000
Video BIOS: 0.0
Current Resolution: 1280 x 1024
* Devices connected to the Graphics Accelerator *
Active Displays: 1
* Digital Display *
Display Type: Digital
Serial Number: ENC1820
DDC2 Protocol: Supported
Gamma: 2.2
Connector Type: DVI
Device Type: Digital Display
Maximum Image Size
Horizontal Size: 13.39 inches
Vertical Size: 10.63 inches
Supported Modes
640 x 480 (60p Hz)
720 x 400 (70p Hz)
800 x 600 (60p Hz)
1024 x 768 (60p Hz)
1280 x 1024 (60p Hz)
Power Management Support
Standby Mode: Supported
Suspend Mode: Supported
Active Off Mode: Supported
Raw EDID:
00 FF FF FF FF FF FF 00 15 C3 20 18 01 01 01 01
11 13 01 03 80 22 1B 78 EA EE 95 A3 54 4C 99 26
0F 50 54 A1 08 00 81 80 01 01 01 01 01 01 01 01
01 01 01 01 01 01 30 2A 00 98 51 00 2A 40 30 70
13 00 52 0E 11 00 00 1E 00 00 00 FF 00 33 34 38
37 32 30 34 39 0A 20 20 20 20 00 00 00 FD 00 3B
3D 1F 40 0B 00 0A 20 20 20 20 20 20 00 00 00 FC
00 53 31 37 32 31 0A 20 20 20 20 20 20 20 00 F1
* Other names and brands are the property of their respective owners.[/quote]
HEarl
Attached, the file is
Cesar_B_Intel
Thanks for sharing the graphics reports, we will proceed to investigate this issue and let you know of any updates as soon as possible.
Caesar B_Intel.
HEarl
No rush, we've been waiting for 2 years 😜
Cesar_B_Intel
Hello MeinWasser
Thanks for your patience.
Caesar B_Intel.
