22680 ディスカッション
Artefact in SC2 with HD4000
従業員
3,268件の閲覧回数
Just got a pc with a I7 3712QM and noticed artefact/crahes in SC2 with HD4000.
I installed drivers from /message/157886 http://communities.intel.com/message/157886.
It has solved the crahes but I still have artefacts and performance issues with SC2.
Artefacts seem to appear when the corruptor unit is on the screen. (easily reproducible on my pc)
(Otherwise, can play D3 fine, also tested memory OK)
@ all: anyone noticed the same problem?
@ Intel: Can you please investigate/tell me if the issue is known and if there are new drivers coming?
There are several posts on the net reporting similar issues with HD4000 and SC2.
0 件の賞賛
5 返答(返信)
MSchm21
高評価コントリビューター I
2,095件の閲覧回数
Do you have a screenshot with artefacts on it?
従業員
2,095件の閲覧回数
A little difficult to catch since it appears/disappears quickly but here is a small one:
I have flicker with this kind of blue/black lines.
従業員
2,095件の閲覧回数
other screenshots:
従業員
2,095件の閲覧回数
I have the same issue, also using HD4000. About to update my driver to the december release, currently on the driver released before that
EDIT most recent driver doesn't seem to have the issue. On low settings there'll be a flicker on rare occasion, but it didn't seem to occur with medium shaders. This issue may've been fixed in an earlier release though, since I mostly noticed the issue when I started in September
Fred_D_Intel
従業員
2,095件の閲覧回数
返信
