Please Intel and Asus or Microsoft there is conflict in the driver update Intels and windows update, need to get your drivers straight you make me update to many times because you do not recognize Microsoft or Asus driver.
Thanks its not fare it to the customers.
So the Intel support engineers can have more information about your system, Please download and run the Intel System Support Utility (https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility-for-Windows- ) for Windows. Select all data categories and then have it generate a report. Next, have the tool Save the report to a text file (don't try to use the Submit capability; it doesn't work). Finally, using the Drag and drop here or browse files to attach dialog below the edit box for the body of your response post, upload and attach this file to the response post.
