23269 Discussions
Audio Lag HDMI port (2s) [Intel Corporation HD Audio for Display Audio driver]
Tio-do-mato
Hello everybody!
My laptop is the Inspiron 15 5510 [Windows 11 model (updated)].  Latency is 3s in hdmi port only in exclusive mode (direct Sound Windows works normally).
driver version: 31.0.101.4499
Date : 07/06/2023
HDMI Device port: SONY Soundbar MODEL [HT-G700] (last firmware update) [2.111]
Audio software: Foolbar2000 v2.1 [x64]
Ouput: Exclusive mode (set on)
Windows 11 PRO
Versão 22H2
Instalado em ‎20/‎09/‎2022
Compilação do SO 22621.1848
Experiência Windows Feature Experience Pack 1000.22642.1000.0
Could you help me?
Enrico
Jean_Intel
Hello Tio-do-mato,
Thank you for posting once more into the Intel️® communities. We would be more than glad to help you with your issue.
Based on your previous thread, we recommended you perform a clean driver installation, installing the latest version from Dell, driver version 31.0.101.3616. Note that the HDMI port is normally handled by your graphics adapter, even if it is only an audio device. Doing a clean install of the software/drivers for any hardware can help to fix specific issues that can be associated so any additional software that might be causing malfunction.
In case the issue is still present, we would like to further investigate this matter. However, we would like to confirm the following information:
  • Share a video recording showing the problem.
  • We would like to ask for more system information. Please, create a system report using the Intel®️ System Support Utility (Intel®️ SSU):
    • Download the Intel SSU
    • Open the application and click "Scan" to see the system and device information. By default, Intel®️ SSU will take you to the "Summary View."
    • To save your scan: click "Next"; then "Save."
Best regards
Jean O.
Jean_Intel
Hello Tio-do-mato,
We hope you are doing fine.
Jean O.
Jean_Intel
Hello Tio-do-mato,
Best regards.
Jean O.
