23085 Discussions
Audio only plays out of 1 HDMI port at a time
TTimF
Does the HD4000 Video card support Audio out of both HDMI ports at the same time?
Hi tforney,
The main display will provide with the Audio; it is possible to change the configuration from play back devices (right click Audio icon)
Mike C
Hi tforney,
Mike C
TTimF
So If I understand what you are saying an audio stream can only play out of a single HDMI output at a time and that 2 separate Audio streams cannot be played out of both HDMI ports simultaneously. Is that correct?
Hi tforney,
Yes, you are correct. Only one at a time.
Mike C
Hi tforney,
I am following your case. Let me know if you need further assistance.
Mike C
