22945 Discussions
Intel HD Graphics 520 is crashing often
LAmsa
I have a Dell laptop with windows 7, and there is an error with the Intel HD Graphics.
Its shows an error : "display driver stopped responding and has recovered".
When this massage shows, the screen is flickering, and its happens often.
I tried to search in the community about this problem, and i found similar topics about the same problem, maybe this is a general issue?
I tried to uninstall the intel hd display driver and the dell display driver and reinstall them,
I have tried to install also the intel hd graphics beta driver, but its not working also.
Can you please assist me with this issue?
Thank you,
Liav
Hi Amsalem,
Intel® HD Graphics 520 comes with the latest 6gen processors; the support for Windows® 7 and 8.1 is limited for pre-build systems. Intel offers drivers for Windows® 7, 8.1 and 10 for customized systems.
It is necessary to verify with Dell support website if there are compatible drivers for Windows® 7. Dell customizes our drivers.
Latest drivers on the link below:
http://www.dell.com/support/home/us/en/04 http://www.dell.com/support/home/us/en/04
Mike C
Hi Amsalem,
Mike C
LAmsa
Hi Mike,
Thank you for your response.
I tried install the Intel HD graphics from Dell site, the last driver update for my model "Latitude E5470" is from 17 Mar 2016.
But its not working for me.
Liav
Hi Amsalem,
I am following your case. Let me know if you need further assistance.
Mike C
LAmsa
Hi Mike,
Tried to apply also new Windows updates to this graphics driver, but still not working.
Thank you,
Hi Amsalem,
Please download and run our Intel® System Support Utility and send to me the results. Also, paste a screenshot of the error message.
https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility
Note: How to attach a file
Click reply, On upper right corner click "Use advanced editor", Lower right section click "Attach"
Mike C
LAmsa
Hi Mike,
I attached to this reply the screenshot of the error message, and also the Intel System support utility results.
Thank you for your help!
Hi Amsalem,
I reviewed the results and I noted you are using an older BIOS version and chipset driver. I suggest you to use Dell's tool to update your computer.
The service tab is on the bottom of your laptop.
http://www.dell.com/support/home/us/en/19/Products/?app=drivers http://www.dell.com/support/home/us/en/19/Products/?app=drivers
Second option:
Select the Auto-detect option.
Mike C
Hi Amsalem,
Mike C
