22689 Discussions
BSOD possibly due to Intel HD Graphics 4400
fABBA1
I just joined this community to inform and to discuss with u a very important problem.
I bought my VAIO laptop 1.5 months back with model name SVF15328SGW, Since then i have problem so slow response and frequent windows crashes. I followed the problem and did everything that the experts on internet said and also consulted internet and Sony service center but the problem was not solved. The problem was very poor performance of Notebook and BSOD whenever i used to wake it up from sleep. Yesterday i disabled Intel HD graphics from Device manager and noted that after it is disabled i can't put the pc to sleep because the option of sleep was lost. Then i realized it might be the Intel HD Graphics 4400 drivers that causing the problem. So i followed the instructions and Installed Beta drivers from intel site instead of drivers supplied by Sony. The performance problem is almost solved and Notebook is performing quite well. and The BSOD problem still persists. Kindly help me solve this problem.
fABBA1
Thank u for u concern....
Can u kindly tell me what sort of drivers these are. I gave my laptop to sony service center 2 days back as they suspected defect in preinstalled windows 8.1 which came with laptop and they r installing windows via recovery disc which they say will wipe out every bit of hard disk n old windows n ll install new 1 plus the recovery parition. But I dont think so that the BSOD is due to windows error as windows doesnt show any file missing r corrupted. Even they installed Windows via an image they ve n in this process I dont knw what they did they corrupted resue mode n recovery wizard system which works via assist button and laptop shows error YOUR PC NEEDS TO BE REPAIRED......ERROR 0xc0000225.
I ll probably get it back today and ll test these drivers.
But I suspect faulty hard disk as it gets hot during normal PC functionality. Its toshiba mq01abd050 500GB wd 5400rpm.
ROBERT_U_Intel
@ farrukh, The drivers in the links above are the latest Intel HD Graphics drivers available for the Intel HD Graphics 4400.
Robert
DChro
I have an Asus N55JK. I was running the "Windows 10" Intel driver and was having the BSOD coming from sleep. Switch to this older driver and it seems to have fixed the issue.
