23825 Discussions
Bad image error
Twins1
So, I bought my new pc 1 week back- Acer ALG i5. Recently this message has been showing up constantly when I,m trying to open few applications like Blue stacks, Creative app. The error is -
C:\WINDOWS\System32\DriverStore\FileRepository/iigd_dch.inf_amd64_6a13a6d40d93da6f\igc32.dll is either not designed to run on Windows or it contains an error. Try installing the program again using the original installation media or contact your system administrator or the software vendor for support. Error status Oxc000012f.
It pops like 10 times constantly after I close it.
ACarmona_Intel
Hello Twins1,
Please generate an SSU report to help me further analyze your system specifications and configurations. To generate the SSU report, please refer to the article: How to Get the Intel® System Support Utility Logs on Windows. Please send me the generated SSU.txt file.
Carmona A.
ACarmona_Intel
Hello Twins1,
I am checking in with you to see if you already have the information that I requested in order for me to continue to further investigate our issue.
Thank you!
Carmona A.
Twins1
Sorry for late reply .this is my system configs
ACarmona_Intel
Hello Twins1,
Thank you for sharing with me your SSU.
Upon checking, you have 2 graphics cards in your system:
  1. Intel UHD Graphics
  2. NVIDIA GeForce RTX 3050.
For our next step, if your system is using the Intel UHD Graphics, please try to clean install your graphics driver using DDU, then install our latest driver: Intel® Graphics Driver 32.0.101.6460/32.0.101.6259.
And if your system is using NVIDIA GeForce RTX 3050, please contact NVIDIA support  so they can guide you on how to perform a clean installation with their graphics driver.
If the issue still persists, please run System File Checker in CMD.
1. In the Command Prompt window, type the following command, and press ENTER:
sfc /scannow
Warning: Do not close this Command Prompt window until the verification is 100% complete.
2. Once done, close CMD.
You may also check the below third-party link, as it seems to be related to the issue in our case:
Carmona A.
ACarmona_Intel
Hello Twins1,
I would like to know if you have any questions regarding the recommendation that I have provided.
If so, kindly inform me, as I would be glad to assist you.
Carmona A.
Twins1
I read your reply and i will do as you have instructed and inform you the result asap.
ACarmona_Intel
Hello Twins1,
Thank you so much for the update and cooperation.
I'm looking forward to your next response.
Carmona A.
JohnM_Intel
Hello Twins1,
My colleague Andre is currently out of the office, so I'll be the one who will handle this case for now. If you need help, just kindly post here, and I'll do my best to support you with your concern.
John Sergio M.
JohnM_Intel
Hello Twins1,
Posting this as a follow-up, just want to know if you are done with the troubleshooting steps my colleague provided you. If yes, kindly acknowledge this post by replying.
John Sergio M.
JohnM_Intel
Hello Twins1,
John Sergio M.
