Hello to everyone.
I am facing problem in running Battlefield 3 game on my laptop.
This is the screenshot of error.
I have Dell Inspiron 15R laptop with Core i3 processor, 1696MB of graphics card, 6GB RAM, Windows 7 Home Basic 64bit.
Please any one help me....i played Mass Effect 3, Call of Duty:MW, Call of Duty:MW2, Call of Duty:MW3, Call of Duty:Black Ops, Crysis, Crysis 2, Operation Flashpoint:Red River, Ranbow Six Vegas 2, and many more games.
Hi there!
The screen shot refers to DirectX, you may want to update Microsoft DirectX version from Microsoft site, also check the list of tested games for your graphics controller.
http://www.intel.com/support/graphics/sb/CS-031017.htm http://www.intel.com/support/graphics/sb/CS-031017.htm
Try updating to the latest graphics drivers here: http://downloadcenter.intel.com/Detail_Desc.aspx?agr=Y&DwnldID=20842&ProdId=3231&lang=eng&OSVersion=Windows%207%20%2864-bit%29*&DownloadType=Drivers http://downloadcenter.intel.com/Detail_Desc.aspx?agr=Y&DwnldID=20842&ProdId=3231&lang=eng&OSVersion=Windows%207%20%2864-bit%29*&DownloadType=Drivers
Allan
Very very thanks for your reply.
I checked on the list of games supported on my graphics card, but there is no name of Battlefield 3.
And thanks for the driver of latest graphic, but i have dell laptop and i just check an update through my laptop but there is no any update.
But still i am downloading it.
Thanks.Keep replying.
While installing the driver i got an error.
Actually I am using 2G net and speed is only 10-15KBPS.
So very slow net.
So please give me right solution.
And i think that there is no any update for my laptop driver.
Because i also went in official site of dell.But there is no any latest driver.
I removed the driver of intel graphics card and then installed the previous version and now new error comes.
And then i again install the newer version means that came with laptop.
Still same problem.
error snapshot.
some time in fault module name :-igd10umd32.dll and some times also ntdll.dll
but i already have these two dll in my sysWOW64 and also in system32.
now tell me what should i do??
please post a screenshot from Intel HD Graphic Setting\Info Center !
i think your Laptop reserved only 64MB/128MB Shared Memory.
yes you have only 64MB reserved vram. for Battlefield 3 you need minimum 512mb vram.
show in your Motherboard Bios, if you can change the (iGFX) Shared Memory to 512mb or better 1024mb.
Otherwise you need to update your motherboard bios, or ask the Manyfactory support.
Sorry to ask how can i give you Motherboard bios.
I do not know.
And please also give me link for newer version of graphics card.
You have newer version.
From where you downloaded it??
If you Start your Laptop, it show to you a messge (For Setup the bios Press F2 or F12). You see this message 3 or 5 Seconds.
Then search in the Bios menu for Shared Memory or iGFX or iGPU or Onboard VGA Memory.
I already downloaded it but setup is not completed because of my laptop.
When ever i tried to open it then fully black screen comes.
After that i pressed alt + tab then there i saw only loading screen in right bottom of the screen.
And again i have to forecly close the bf3 program.
Last night, for the first time, game was played by me.
After that i tried many times but same loading screen.
