J'ai effectué toute les mises à jours windows.
J'ai dans les journaux windows :
<?xml version="1.0" encoding="utf-16"?>
<InstallationDevice>
<IDUUVersion>19.6.26.3</IDUUVersion>
<Region>fr</Region>
<InstallerName />
<OS>Windows® 10, 64-bit*</OS>
<Bitness>64-bit</Bitness>
<DriverClassGUID>4d36e968-e325-11ce-bfc1-08002be10318</DriverClassGUID>
<HardwareSignature>VEN_8086&DEV_1912</HardwareSignature>
<CurrentDriverDate>18/11/2018</CurrentDriverDate>
<DriverDescription>Intel(R) HD Graphics 530</DriverDescription>
<DriverManufacturer>Intel Corporation</DriverManufacturer>
<InfFilePath>C:\Windows\Inf\oem39.inf</InfFilePath>
<VersionBeforeInstallation>25.20.100.6323</VersionBeforeInstallation>
<VersionAfterInstallation>25.20.100.6323</VersionAfterInstallation>
<DriverID>28888</DriverID>
<FileName>igfx_win10_100.6912.exe</FileName>
<Type>Graphics</Type>
<AvailablePackageVersion>26.20.100.6912</AvailablePackageVersion>
<AvailablePackageDate>2019-06-19T16:00:00.0000000</AvailablePackageDate>
<AvailablePackageName>Graphiques Intel® - Windows® 10 pilotes DCH</AvailablePackageName>
<DownloadedURL>https://downloadmirror.intel.com/28888/a08/igfx_win10_100.6912.exe</DownloadedURL>
<InstallSuccessful>True</InstallSuccessful>
<InstallResult>Success</InstallResult>
<Timestamp>2019-07-13T18:51:35.2631620Z</Timestamp>
</InstallationDevice>
Hello Hboo0,
Thank you for posting on the Intel ® communities.
I would like to have more information of the system you have, please provide me with the model of the computer/laptop if applicable, as well as an System Support Utility report, this report can be generated from our tool, you can refer to the link below so you can download it:
https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility-for-Windows-
Make sure to attach the created report to this thread.
David V
Under Contract to Intel Corporation
Hello DavidV_Intel
The report --> http://www.mediafire.com/file/6kbpoffigrwhfct/Detailed-System-Report.html/file
Hello Hboo0,
Thank you for your response.
Please attach the report to the thread directly, when you are responding you have the option to attach a file, refer to the screenshot attached to this post.
David V
Yes but i can't upload html page, (You can only upload these file types: 7z, ai, bmp, bz2, c, cdr, cpp, css, csv, cxx, dib, dmp, doc, docx, eml, eps, f, f90, for, gif, gz, gzip, h, i, ico, icproj, img, jfif, jpe, jpeg, jpg, log, mdb, mdl, mov, mp4, odp, ods, odt, pdf, pjpeg, png, pps, ppsx, ppt, pptx, psd, qar, rar, rtf, rtx, sel, sig, sln, tar, tbz2, tgz, tif, tiff, txt, txz, v, vcproj, vcxproj, vfproj, vhd, vtt, wks, xcf, xls, xlsx, xml, xz, zip.)
Intel® Driver & Support Assistant
Detailed Report
Last scan: 16/07/2019 17:42
Computer
Gigabyte Technology Co., Ltd. Z170XP-SLI System Manufacturer Gigabyte Technology Co., Ltd. System Model Z170XP-SLI System Type Desktop Motherboard Manufacturer Gigabyte Technology Co., Ltd. Motherboard Product Z170XP-SLI-CF BIOS Version BIOS Date: 03/07/16 11:49:52 Ver: 05.0000B SMBIOS Version 2.8
Operating System
Microsoft Windows 10 Professionnel (64 bits) Version 1607 OS Build 10.0.14393 Build Branch rs1_release Locale Français (France) Windows Directory C:\Windows System Directory C:\Windows\system32 .NET Framework Versions 2.0.50727.4927, 3.0.30729.4926, 3.5.30729.4926, 3.5.30729.5003, 4.0.0.0, 4.7.02053 Installed Internet BrowsersMozilla Firefox
Processor
Intel® Core™ i5-6500 CPU @ 3.20GHz
Manufacturer GenuineIntel
Description Intel64
Family 6
Model 94
Stepping 3
Architecture x64 # of Cores 4 # of Threads 4
Processor Base Frequency 3201 MHz
Current Voltage 1.7
Level 2 Cache 1024 Kb
Level 3 Cache 6144 Kb
Processor Id 0x506E3
Revision 24067
AvailabilityRunning at full power
Chipset
Intel® 100 Series/C230 Series Chipset Family
Intel® HD Graphics 530 Adapter Compatibility Intel Corporation Video Processor Intel® HD Graphics Family Resolution 1920 x 1080 Bits Per Pixel 32 Number of Colors 4294967296 Refresh Rate - Current 60 Hz Refresh Rate - Maximum 75 Hz Refresh Rate - Minimum 50 Hz Driver Provider Intel Corporation Driver Version 25.20.100.6323 Driver Date 18/11/2018 Adapter DAC Type Internal Adapter RAM 1,00 GB Availability Running at full power Status This device is working properly. Location PCI bus 0, device 2, function 0 Device IdPCI\VEN_8086&DEV_1912&SUBSYS_D0001458&REV_06\3&11583659&0&10
Audio
Périphérique High Definition Audio Driver Provider Microsoft Driver Version 10.0.14393.0 Driver Date 15/07/2016 Device Id HDAUDIO\FUNC_01&VEN_10EC&DEV_0900&SUBSYS_1458A182&REV_1000\4&11D6FE01&0&0001 Son Intel® pour écrans Driver Provider Intel® Corporation Driver Version 10.26.0.1 Driver Date 09/04/2018 Device Id HDAUDIO\FUNC_01&VEN_8086&DEV_2809&SUBSYS_80860101&REV_1000\4&11D6FE01&0&0201 NVIDIA Virtual Audio Device (Wave Extensible) (WDM) Driver Provider NVIDIA Driver Version 4.4.0.0 Driver Date 13/12/2017 Device IdROOT\UNNAMED_DEVICE\0000
Networking and I/O
Intel® Ethernet Connection (2) I219-V Manufacturer Intel Availability Running at full power Status This device is working properly. Installed True MAC Address 1C:1B:0D:6A:E2:48 Service Name e1dexpress Driver Provider Intel Driver Version 12.15.23.9 Driver Date 26/10/2016 Device Id PCI\VEN_8086&DEV_15B8&SUBSYS_E0001458&REV_31\3&11583659&0&FE Revision 31 TeamViewer VPN Adapter Manufacturer TeamViewer GmbH Availability Running at full power Status This device is disabled. Installed True Service Name teamviewervpn Driver Provider TeamViewer GmbH Driver Version 2.10.0.0 Driver Date 27/11/2007 Device Id ROOT\NET\0000 TAP-Windows Adapter V9 Manufacturer TAP-Windows Provider V9 Availability Running at full power Status This device is working properly. Installed True MAC Address 00:FF:36:89:C8:F6 Service Name tap0901 Driver Provider TAP-Windows Provider V9 Driver Version 9.0.0.21 Driver Date 21/04/2016 Device Id ROOT\NET\0001
Memory
16 GB Physical Memory - Total 16 GB Physical Memory - Available 12,77 GB Virtual Memory - Total 18,24 GB Virtual Memory - Available 15,00 GB Page File C:\pagefile.sys Page File Space2,38 GB
Hello Hboo0,
Let's try the following, please go into device manager.
1 - Open "Display Adapters".
2 - Right-click on "Intel Graphics".
3 - Select uninstall until the display adapter shows as "Microsoft basic display adapter".
4 - Right-click on it and select "Update driver"
5 - Let the update go and after done, restart your system and check it again with Intel ® Driver & Support Assistant.
I hope this helps.
David V
Hello David V,
Thank you for your help.
I still have the old version that installs after the update (25.20.100.6323) and with Intel ® Driver & Support Assistant, i have again one software update available.
Dernière version: x.x.x.6912
Version installée: x.x.x.6323
Mise à jour disponible
Hello Hboo0,
Let's try to manually install the latest driver for your graphics adapter. Please follow the steps in the link below:
1 - Download the latest DCH driver and save it on the computer.
https://downloadcenter.intel.com/download/28888/Intel-Graphics-Windows-10-DCH-Drivers?product=88345
2 - Disconnect from the Internet so no new drivers are automatically installed by Windows Update.
3 - Uninstall the driver and the Intel Graphics Control Panel from Control Panel > Programs and Features.
4 - Restart the computer.
5 - Confirm in Device Manager > Video Adapters the controller is listed as 'Microsoft Basic Display Adapter' > if not, repeat steps 2 through 4.
6 - If the adapter continues to be listed as ‘Intel HD Graphics’ or similar, and no other Intel Graphics driver is listed under 'Programs and Features' for removal, then it means Windows has switched to a previously installed Legacy driver. At this point we can remove Legacy drivers from Device Manager:
6.1.1 Right-click on 'Intel HD Graphics' or similar, and select 'Uninstall Device'
6.1.2 In the pop-up window make sure 'Delete the driver software for this device' is checked.
6.1.3 Click on 'Uninstall'.
6.1.4 Restart. (Repeat steps 6.1.1 through 6.1.4 until the device gets listed as 'Microsoft Basic Display Adapter')
7 - Install the DCH driver that was downloaded on step 1.
8 - Restart the computer.
9 - Reconnect to the Internet.
Let me know the outcome please.
David V
Hello DavidV,
The result : I can follow the steps up to 7 and i have the error message : This installation package is not supported by this type of processor. I do not understand why.
Hello Hboo0,
I was looking again at the report you attached and I can see that you are running Windows 10 build 1607 which could be the reason why the graphics driver update is not finishing properly.
Please proceed to update Windows* to the latest tested build and afterwards try following the steps I provided above for the graphics driver installation. Refer to the link below in order to update Windows*:
https://www.microsoft.com/en-us/software-download/windows10
* Please be aware that the content on that site is not controlled by Intel*. This information is offered for your convenience and should not be viewed as an endorsement by Intel* for the merchants or services offered there. *
There will be an option that says "Update Now", which should allow you to update to the latest build.
Let me know the outcome.
David V
Hello David V,
Thank you, update Windows to work properly and I was able to install the driver of my graphics card thank you for the time spent on my case.
good continuation.
Hello Hboo0,
I'm really glad to know the update did solve the issue! It has been my pleasure to assist you.
David V
