22660 Diskussionen
Bug Report: HD 520 screen black after wake on driver 15.46.02.64.4729 / 22.20.16.4729
PBixb
Neuer Beitragender I
3.456Aufrufe
When I revert back to 15.45 driver, problem goes away.
Category
Questions
Answers (N/A if not applicable)
Description
Provide a detailed description of the issue
Screen black after wake
Please place an X to the right of the option showing how often you see this issue using specific steps. (Ex: 'Every few times a game is started it flickers.' <- This would be "Often")<p>
Always (100%): X
Hardware (HW)
Brand and Model of the system.
Lenovo Yoga 900 13ISK 80MK
Hybrid or switchable graphics system?
ie Does it have AMD or NV graphics too?
No
Make and model of any Displays that are used to see the issue (see note2 below).
LFP = Local Flat Panel (Laptop panel)
EFP = External Flat Panel (Monitor you plug in)
LFP
<td style="padding: 0 5.4pt; border-top: none; border-right: 1pt solid windowtext; border-bottom: 1pt solid windowtext; border-...
6 Antworten
APMichael
1.634Aufrufe
I can confirm this bug, too! After wake up from S3 the screen is full of flickering green lines. Only a hard power off helps.
I tried the manual installation already.
System: ASUS VivoMini UN65, i3-6100U (HDG 520), Windows 10 (x64, 1703)
MJone10
1.634Aufrufe
I have the same issue. After resuming from sleep monitor is full of vertical lines and the screen flashes. Only hard power off and power on allows me to get back into windows.
PBixb
1.634Aufrufe
Sorry to cross post, but don't want 520 users to miss this from the 630 thread.
Intel Corporation wrote:
trueblue did you download this driver from your computer manufacturer website or you download it from the Intel website?
If you downloaded the driver from the Intel website I suggest you to uninstall it and then reinstall it manually, please see how to https://www.intel.com/content/www/us/en/support/graphics-drivers/000005629.html Manually Install an Intel® Graphics Driver in Windows® 10 and Windows 8*/8.1*
When you uninstall the driver, disconnect the internet, this is to avoid Microsoft to send any update and do not restart the system and then install the driver manually, you can follow the steps from the link above.
You can download the driver zip file here:
https://downloadcenter.intel.com/download/26941/Graphics-Intel-Graphics-Driver-for-Windows-15-46-%3Fproduct%3D98909 Intel® Graphics Driver for Windows* [15.46]
Please let me know how it goes.
Ivan U.
Did I download from my computer manufacturer? You must not be familiar with Lenovo support. They have not updated their "official" graphics driver for this laptop for a year. Nor do I expect any future updates. I've been using generic Intel drivers for a long time.
I had originally installed using the generic Intel .exe file, as I previously disabled Windows Updates for Lenovo's drivers, so the .exe previously installed just fine.
I just uninstalled (including a separate attempt using device uninstall with uninstalling drivers) and reinstalled using the manual .zip. Still have the same problem. Still goes away when I revert to 15.45.
JGatt
Einsteiger
1.634Aufrufe
I'm using the same device and have exactly the same problem.
PBixb
1.634Aufrufe
Ronald_Intel wrote:
Please let me know the following:
1. If you have a laptop, can you reproduce the issue using only the Local Flat Panel (LFP)? how about connecting an external display?
2. What kind of connection you have to the external display? (e.g. DisplayPort-to-DisplayPort, HDMI-to-HDMI, USB-C to DisplayPort)
3. Are you using any kind of adapter or converter?
4. Do you recall enabling/disabling any particular Windows feature? (e.g. Hyper-V).
5. Current Advanced Power Settings, particularly for Sleep, Power buttons and lid, Display and Intel Graphics Settings?
1. When I connect to an external display as either duplicate or extend, it works fine on a fresh boot. Close lid, sleep, wake, and the secondary display is getting a signal, but the screen is black. The LFP is also black. Only a forced reboot will fix.
2. I am using a USB-C to HDMI adapter to the external display.
3. No.
4. No.
5. See attachments.
Sorry for the cross post, but want to make sure everyone interested (and especially Intel) sees this.
RonaldM_Intel
1.634Aufrufe
Hello Everyone,
I would like to confirm that Intel is investigating this issue.
Please refer to this thread: /thread/116427 HD 630 Resume From Standby Screen Flickering
This is where we will be posting all news and updates concerning this situation.
I'll proceed to lock this thread in order to keep all reports under the same thread for increased visibility.
Kindest Regards,
Ronald M.
Antworten
