22745 Discussions
Built in graphics on DH67BL and seperate graphics adapter?
Hi, sorry if I went into the wrong group.
Does anyone know if it is possible to put a separate graphics adapter on the motherboard above AND keep the built in ports (HDMI+DVI) working and thereby connect up to four monitors?
Thanks!
Best regards
J
Hello JnGr,
I see that you are inquiring about the possibility to have the onboard graphics working together with a discrete video card to be able to have 4 simultaneously displays.
Regarding your inquire, currently this is not supported and once you install a video card to the motherboard the onboard graphics will get disabled.
Regards.
