23076 Discussions
Calling wglShareLists leads to access violation in ig9icd32.dll
SergeyXa
I'm currently trying to play with OpenGL in a simple .NET application using OpenGL via OpenTK, and also employing RenderDoc. Both the binaries and the source of the tiny application are attached. I built it using Visual Studio Community, .NET 6.
When the application is executed on a machine with Intel HD 630 (the driver version is - I assume it's the most recent one), I get an Access Violation in ig9icd32.dll on startup. The same exception appears if I build for x64. Running the same app on Vega WX M GL gpu, or on NVidia GeForce 1060 gpu doesn't lead to any issue. So I assume that there's something wrong in the Intel's gpu driver itself.
Could you guys take a look please? Thanks in advance.
Labels (2)
Steven_Intel
Hello SergeyXa,
In order for us to test the code, could you please confirm the driver version you have installed when you get the error?
As well, are you using Intel® HD Graphics 630 or Intel® UHD Graphics 630?
Steven G.
SergeyXa
Hello Steven,
I'm using Intel® HD Graphics 630, and the driver version is 31.0.101.2111.
Steven_Intel
Thank you for your response.
I am going to work on this. As soon as I have an update, I will let you know.
Steven G.
Steven_Intel
Hello SergeyXa,
We were unable to replicate the issue in our lab. Is there anything we could be missing here? Or can you provide guided steps in order for us to try to replicate the issue?
We used a system with Intel® HD Graphics 630 using the latest driver 31.0.101.2111, and we ran the code on Visual Studio with no error.
Look forward to hearing from you.
Steven G.
SergeyXa
Hello Steven,
It's pity that the issue is hard to reproduce. Maybe the minidump can help?
Sergey
Steven_Intel
Steven G.
Steven_Intel
Hello SergeyXa,
After trying to replicate the issue, we were unable to do it successfully in two different machines. At this point, our best recommendation is to contact the app developer for further assistance.
Steven G.
