22680 讨论
Can I disable hot keys for rotation only, leaving other hot keys active?
FAbob
初学者
1,545 次查看
I'm configuring an HP Probook 4540s running windows 7 for someone who needs to use a vast number of their own hot keys, and they don't want the screen rotation keys to work. They do, however, need the monitor selection keys to work. Is there any way to disable JUST the screen rotation keys? I'd prefer not to edit the registry but will if it is the only way - if so, please advise what to edit.
Thank you_on
0 项奖励
1 回复
Kevin_M_Intel
员工
680 次查看
Hi abobo,
Hot Keys can be either disabled or enabled but there is no option to disable certain hot keys.
0 项奖励
回复
