20731 Discussions
Can I get 5.1 from I3 6100 cpu threw hdmi (graphic 530 )?
SSerg12
I'm trying to get multichannel audio from hdmi port.
my system is :
- Asus z170-a Motherboard
- Intel I3 6100 cpu
- 16 GB DDR4 2400 mhz
- Realtek internal audio
- No other VGA
- OS: windows 10 pro 64bit
currently just getting stereo from hdmi intel display port connected to tv and the tv to home theater by fiber.
the playback device is not supporting any audio compression format.
My cheap old notebook can do 5.1 with the same setup.
Any suggestion?
thank you for your time.
Hi Mink,
You are not getting Audio through the HDMI port. Could you please send me your system configuration? If it is possible to send to me the results of Intel® System Support Utility.
SERGiooooo, our upper level is still trying to find a solution with Kodi.
https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility?product=91600 https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility?product=91600
How to attach a file:
-Click on reply
-Click Use advanced editor (upper right side)
-Click Attach (lower right hand)
Mike C
SSerg12
Mike it's not a kodi thingy it's windows driver problem since eveything is working just fine on Ubuntu.
Hi SERGiooooo,
I am really sorry for the issue. Let me review your case with my upper level. Excuse me for the delay on the answer.
Mike C
HMink
Yep no sound trough hdmi at all, her is a printshot of my system config:
And i don't see any hdmi in sound, and hdmi is connected.
And no intelsound in taskmanager:
HMink
And exactly same problem as here
HMink
SSerg12
Mike C
Disregard my case, I've bought a new tv now everything is working just fine.
Thank you for your time
Hi SERGiooooo,
Thank you for your update.
Mike C
