23105 Discussions
Can I update graphic driver when my cpu i5-4460 @3.20GHz is not included ?
DYu11
I have graphic card HD Graphics 4600, want to update to 15.36.28.4332, but my cpu i5-4460 CPU @3.20GHz is not included in the product(s) listed in the download webpage (under "This download is valid for the product(s) listed below"), please see: https://downloadcenter.intel.com/download/25588/Graphics-Intel-Graphics-Driver-for-Windows-7-8-1-15-36-?product=81496 https://downloadcenter.intel.com/download/25588/Graphics-Intel-Graphics-Driver-for-Windows-7-8-1-15-36-?product=81496
Hello dorayu,
You can install that version, the processor may not be listed but that graphics controller included within the processor is on the supported products list. So, just give it a try.
Try one of these methods for the installation;
Let me know how the installation goes.
Amy.
DYu11
I just installed the new version.
I downloaded the zip file of win64_153628.4332
Then I update the driver. I reboot my computer. After that I found that the version is:
10.18.14.4332 (20/11/2015)
Actually I want version 15.36.28.4332. Why does it change to 10.18.14.4332 ?
/thread/113627 dorayu, the version you downloaded was successfully installed. Let me explain why; please take a look at the last 4 digits, notice that the numeration is the same .4332. This indicates that the driver was indeed installed, below you will find a detailed explanation of the schema used by Intel to define the drivers.
Intel uses the following schema to define driver versions:
Driver Baseline: Differentiates different generic driver packages and is often assigned based on the supported platform(s) and operating system(s).
Revision: Used internally during the driver development cycle.
Build number: Last four digits indicate the actual driver number.
http://www.intel.com/content/www/us/en/support/graphics-drivers/000005654.html Understanding the Intel® Graphics Driver Version Number
Amy.
/thread/113627 dorayu, I hope the information posted above helped.
If you need further assistance let us know.
Amy.
