22655 Discussions
Can't Install Graphics Drivers For My INTEL PENTIUM GOLD 5400
Deepak192005
I am not able to install graphic drivers for my INTEL PENTIUM GOLD 5400, As I use Intel Driver Support Assistant then it shows :
"No supported driver or software updates are available for your system."
I even tried to download it manually from intel website but they don't work as it shows the message in the image I posted below
Then I got no other option left rather than buying a external graphic card. But I still wonder what was the problem.System SpecsSystem Specs
Intel Graphic Drivers not workingIntel Graphic Drivers not working
Stefan3D
Deepak192005
I tried didn't worked.
Also I forgot to tell that I use to get this error posted below every time I try to open the driver's setup which I download manually for my processor. So I use to install the graphic driver through the device manager. I don't know if this have any relation with the issue.
If you think there are other possible solutions then please let me know!
Andres_Intel
Hello Deepak192005,
Thank you for posting on the Intel®️ communities. I am sorry to hear that you are having graphics driver installation issues with your Intel® UHD Graphics 610, I will be happy to help you.
To have a better understanding of the situation, please answer the following questions:
Andres P.
n_scott_pearson
Have you tried manually downloading and installing the driver. Here's the one you want, I believe: https://www.intel.com/content/www/us/en/download/776137/intel-7th-10th-gen-processor-graphics-windows.html.
Hope this helps,
Deepak192005
I tried it recently and I tried it today also, here what it says:Something went wrongSomething went wrong
Here is the Error Log File:
Deepak192005
Thankyou all of you for the support, No, Graphic Drivers never worked properly since I've purchased it.
Here is the SSU report file:
Andres_Intel
Hello Deepak192005,
Thank you for your response, all the information provided has been really helpful.
Please follow the steps below and let me know the results:
  • Check Windows* updates:
  1. Click the Start button.
    1. Click in the search field and perform a search for "Windows updates". Select that option.
    2. Select Check for Updates and ensure you have the latest
Andres P.
Andres_Intel
Hello Deepak192005,
Andres P.
Deepak192005
Sorry for the late reply but I was having problem updating my Windows 10. So I installed fresh Windows 10 and was busy doing backup of my important files.
I tried doing clean installation for the graphic driver but resulted as the same errors and issues I posted above. I tried every thing I could do but the issue remains the same.
Andres_Intel
Hello Deepak192005,
Thank you for your answer, it has been very helpful.
Andres P.
Deepak192005
I tried clean Installation by the Installer you gave me link of and also installing manually through device manager, No matter which installer I used always gets the same error and issue as posted above. I don't know why this issue coming and have no hope for the solution now.
Thankyou.
Andres_Intel
Hello Deepak192005,
Andres P.
Andres_Intel
Hello Deepak192005,
Andres P.
