22656 Discussions
Can't do dual screen using Citrix receiver and an Intel 630 graphics card laptop
ADemp1
Hi all,
I currently use Citrix Receiver for working remotely. I recently purchased a new laptop and now am having issues extending my display to a second screen when logged in remotely (it only occurs when logged in with Citrix). Approximately a third of the second screen is missing and the mouse cursor in both screens is off centre (does not click where cursor is). I've searched online and believe the issue is related the following link on your the Citrix site:
https://support.citrix.com/article/CTX261911
I followed the instructions in the link above but it didn't resolve the issue (although this is my first time doing something in registry so perhaps I made a mistake). Can someone please assist me with this? I'd really appreciate anyone's input. Our IT team were unable to resolve the issue and said they'd already discussed this with a Citrix Advisor and nothing could be done. My laptop specifications are as below. The laptop model is Lenovo IdeaPad L340 Gaming.
Please note that I've seen the exact same issue on a completely separate laptop which has the same integrated graphics. I find it hard to believe that anyone who purchases a new generation laptop can't use Citrix for dual screen.....? I've seen people report the same issue on forums across the internet (e.g. intel community forums, reddit, Citrix forum etc.) but I can't seem to see a solution anywhere.
On my old laptop I never encountered the issue (older graphics).
Operating System: Windows 10 Pro 64-bit (10.0, Build 18363) (18362.19h1_release.190318-1202)
Language: English (Regional Setting: English)
System Manufacturer: LENOVO
System Model: 81LK
BIOS: InsydeH2O Version 05.23.04BGCN24WW (type: BIOS)
Processor: Intel(R) Core(TM) i7-9750H CPU @ 2.60GHz (12 CPUs), ~2.6GHz
Memory: 16384MB RAM
Available OS Memory: 16264MB RAM
Page File: 4258MB used, 14948MB available
Windows Dir: C:\Windows
DirectX Version: DirectX 12
Displays Devices are as below:
Card name: Intel(R) UHD Graphics 630
DDraw Status: Enabled
D3D Status: Enabled
AGP Status: Enabled
Card name: NVIDIA GeForce GTX 1050
D3D Status: Enabled
AGP Status: Enabled
AlHill
Download, run, and ATTACH (using the paperclip under the toolbar) the results of this utility:
https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility
Doc
ADemp1
Thanks for getting back to me! I've attached the txt file from the scan. Let me know if this is what you need. Thanks a lot!
ADemp1
Hi! I managed to get this fixed! A IT guru helped me out and the solution was actually quite straight forward. I just needed to disable the integrated graphics card. It's now extending fine. Thanks though! 🙂
n_scott_pearson
That's good to know ('cause there's typically no one here who knows much about Citrix 😨).
ADemp1
Thanks Scott, got there in the end! 🙂
